Date/Time: Sun, 19 May 2024 04:36:59 +0000
Swing high and low indicator
View Count: 1085
[2017-04-28 16:08:28] |
User529762 - Posts: 25 |
Is it possible to place a the Swing High and Low indicator on a study in region 2? I would like it to extend the swing high and lows in the region 2 study. I have tried this but does not work can you advise if possible ?
[2017-04-28 17:26:15] |
No. This is not supported. You can modify the study to meet your requirements. Refer to: http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-28 17:34:34] |
Sawtooth - Posts: 4000 |
I have used the Highest High/Lowest Low Over N Bars study for this purpose.
