Date/Time: Sun, 19 May 2024 01:39:09 +0000
Does SC support option quote board for option chain?
View Count: 1067
[2017-04-28 14:26:35] |
naqviak - Posts: 22 |
I have few question: 1. Is it possible to open an option chain in a quote board format? 2. if not can it be done via ASCIL programming? 3. Does SC support custom GUI development? |
[2017-04-29 01:04:25] |
1. You have to manually create this using the Quote Board: Getting Quotes You should be able to get an options chain through through the Interactive Brokers Trader Workstation. 2. No. 3. Not really. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
