Date/Time: Sat, 18 May 2024 18:26:08 +0000
Can I connect to 2 services at the same time - one for data and 2nd for trade?
View Count: 685
[2017-04-28 14:24:01] |
naqviak - Posts: 22 |
Can I use data feed from IQFeed and trade with broker like Interactive broker and TD Ameritrade?
[2017-04-28 17:31:04] |
You can do this but not with IQ Feed. You need to use the Sierra Chart Exchange Data Feed for this. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-28 17:32:27] |
but I need to monitor index options - Does Sierra chart provide them?
[2017-04-28 17:54:52] |
Not with the Sierra Chart Exchange Data Feed but you can definitely receive this data with the Interactive Brokers data feed. We would think that options data from them should be acceptable because option symbols do not frequently trade. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-28 17:55:34
