Date/Time: Sun, 19 May 2024 01:42:05 +0000
Poloniex
View Count: 1605
[2017-04-28 13:41:12] |
User733502 - Posts: 44 |
Hi SC, Under the crypto currency Poloniex exchange in the symbol list you have the Bitcoin Ethereum cross as BTCETH it should be ETHBTC. Can you publish the ETHBTC symbol? Thank You! JS |
[2017-04-28 17:35:49] |
Update to the current version of Sierra Chart: http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#FastUpdate And then perform a Full Reset of the symbol settings: http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps For Poloniex you need to use the Get Symbols command button. There are no longer any pre-listed symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
