Date/Time: Mon, 13 May 2024 01:27:16 +0000
IB Multiple Accounts Setup
View Count: 722
[2017-04-27 16:07:11] |
User603009 - Posts: 9 |
Hello I have an 2 IB both use the same login credentials, in ninjatrader all I had to do was use the drop down in chart trader to select an account to use. How do I get Sierra to do the same? It would be handy as I trade the same instrument in each account, one being my TFSA. Thanks |
[2017-04-27 17:39:29] |
Assuming we understand this correctly, you just need to select the trade account. Refer to: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SelectingTradeAccount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
