Date/Time: Mon, 29 Apr 2024 12:42:36 +0000
Historical datas for FDAX
View Count: 2014
[2013-04-03 06:53:59] |
Tintin - Posts: 23 |
I use SC + TT for live datas + SC Historical Data Service. I try to find a symbol for a continuous historical daily chart for FDAX futures but no symbol works for that. I've decided to use quaterly historical daily FDAX future symbol but it's not possible to join past datas in the "Chart / Perform futures symbol rollover" ... Is there a valid continuous historical daily FDAX futures symbol with SC Historical Data Service ? if no one exists, please can you add the possibility to join past datas when we use historical daily charts ? Regards. Date Time Of Last Edit: 2013-04-03 07:00:21
[2013-04-03 07:25:39] |
Symbol is: DY# Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
