Date/Time: Sun, 12 May 2024 00:52:53 +0000
Question on Copy Chart Drawing
View Count: 652
[2017-04-27 09:49:15] |
NumbersBars - Posts: 141 |
Version 1549: I have chart drawings done on Chart #1. And Chart #2 set to copy drawings from Chart #1. However, I notice that in the latest version of SC, I am able to remove chart drawing from Chart #2, and at the same time, it is removed from chart #1 as well. Is this working as design? As I remember chart drawings can only be deleted from the original chart, not the one that copies it. Please let me know if my understanding is wrong. Thanks. |
[2017-04-27 10:10:58] |
Yes this is correct. This is now supported. Refer to the What is New page for further information: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-27 10:11:52
[2017-04-27 10:36:22] |
Thanks for the quick reply. I noticed a behaviour: I have "Allow Modification of Chart Drawings frm Other Charts" unticked/disabled in Chart #1. However, I am still able to delete the copied chart drawings from Chart #2. (Drawing on both Chart #1, and Chart #2 are removed). To prevent this, both Chart #1, and Chart #2 needs to have "Allow Modification of Chart Drawings from Other Charts" unticked/Disabled. Not sure if this is part of the design. You might want to add this to your documentation. |
[2017-04-27 10:48:01] |
What is the method you are using to delete the drawing? That option only applies on the destination chart. It needs to be disabled on the destination chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-27 10:49:48
[2017-04-27 10:54:25] |
I drew extending rectangle on Chart #1, copied to chart #2. On Chart #2, right click->Erase drawing. [Update] Just read your reply about set the option on Destination chart. I have no issue here. Thanks. Date Time Of Last Edit: 2017-04-27 10:55:58
