Date/Time: Fri, 10 May 2024 20:54:34 +0000
Is it possible to apply several studies without losing existing?
View Count: 680
[2017-04-27 07:39:03] |
fjgaspar - Posts: 62 |
Hi, I have a bookchart with 10 different charts. All charts are for the same symbol. Each chart has different settings: one is a 5 min chart, other 1 min, other 400 tics, other 4 tics range, etc. Each chart has several studies applied. I would like to quickly add 3 studies with same settings to all 10 charts keeping each own studies. If I create a collection with the three studies and apply the collection to one chart, it lose all studies that previously have. If I link the charts, all linked charts ends with the same studies. Is there any way to apply those 3 (or whatever number) studies to a chart without lossing existing ones, and without having to insert and configure them one by one? |
[2017-04-27 07:41:10] |
Sorry, I think I have found how. :-)
[2017-04-27 17:36:31] |
For reference, you need to use Chart Linking and link studies. Refer to: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChartLinking And you need to set a Study Collection to prompt to remove studies. Refer to: http://www.sierrachart.com/index.php?page=doc/StudyCollections.html#AddingStudyCollectionWithoutClearingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
