Date/Time: Fri, 10 May 2024 04:28:20 +0000
CQG Fix Global Symbol Settings for S&P eMini (symbol F.US.EPM17)
View Count: 1092
[2017-04-26 22:32:55] |
User956467 - Posts: 30 |
When updating from server Session Start Time: is 18:00:00; Session End Time: is 17:59:59 and Evening Start Time: is 00:00:00; Evening End Time: is 23:59:59. Should times be 09:30 to 16:14:59 and evening 18:00:00 to 16:59:59? These are the times the NQ update to. Thanks. |
[2017-04-27 04:05:53] |
What you can use are these: 09:30:00 to 16:14:59 Evening 16:15:00 to 9:29:59 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-27 10:04:46] |
1. CQG Fix "Update from Server" still produces incorrect times for the ES (cqg symbol F.US.EPM17). 2. The NQ (cqg symbol F.US.ENQM17) and YM (cqg symbol F.US.YMM17) "Update from Server" both produce Day Session 09:30 to 16:14:59 and Evening 18:00 to 16:59:59 which is PERFECT. 3. Can you update CQG Fix "Update from Server" for the ES (cqg symbol F.US.EPM17) to the same times as the NQ and YM? Evening Session from 18:00:00 to 16:59:59 and Day Session from 09:30:00 to 16:14:59, please. Thanks. |
[2017-04-27 19:00:36] |
We will work on this.
