Date/Time: Sat, 04 May 2024 17:46:21 +0000
User Email Questions - CandleStick Patterns Finder
View Count: 1348
[2013-08-20 22:51:02] |
Sierra Chart - Max - Posts: 5605 |
Is it possible to use more than 6 candlestick patterns on the candlestick patterns finder or is this the maximum that can be used?
Sierra Chart Support |
[2013-08-23 10:31:19] |
Yes, by adding more than one instance of the Candlestick Patterns Finder study to the chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-07 00:44:19
