Date/Time: Fri, 10 May 2024 02:18:10 +0000
fib tool
View Count: 1029
[2017-04-26 12:15:46] |
User25244 - Posts: 123 |
Does sc have a fib tool tht expnds to 423.6% to -323.6% ? the retracement and expansion tools do not extend this far Date Time Of Last Edit: 2017-04-26 12:16:08
[2017-04-26 12:28:21] |
I think i found the answer disregard |
[2017-04-26 13:22:32] |
the fib tool in sc shows different levels then the fib tool in ib is there a way of adjusting it to reflect IBs tool?
[2017-04-26 17:17:38] |
What you are referring to is the Price Retracement tool. Follow the instructions here to configure it: http://www.sierrachart.com/index.php?page=doc/Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-26 19:27:04] |
I was referring to retracement and expansion There are a couple of things that seem odd to me 1. i used the retrcement/expansion on ib as well as sc and the 2 are very different considering the % are the same and the hi and low are the same the exp/retrace points should b the same 2. the fixed daily pivots in SC are also much different then IB's again the data to calculate should be the same therefore the outcome shuld also be the same I find IBs to be more accurate but would prefer using SC's is there a way to adjust this? |
[2017-04-27 05:01:02] |
1. Post an image of a chart showing this drawing: "retrcement/expansion" Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image 2. Refer to: Pivot Points are not Accurate or are Different Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
