Date/Time: Sat, 11 May 2024 18:52:49 +0000
cant get charts up
View Count: 874
[2017-04-25 04:15:29] |
User716402 - Posts: 28 |
Still trying to get the charts up Cant connect to rithmic This is a continuation of the earlier thread.tried downloading current, previous and pre release no luck Reading Internal Order ID file. | 2017-04-24 22:24:58 Reading Trade Orders file. | 2017-04-24 22:24:58 Reading Trade Positions file. | 2017-04-24 22:24:58 Listening on UDP port 22903. | 2017-04-24 22:24:58 Software version: 1547 | 2017-04-24 22:24:58 Uses New Spreadsheets | 2017-04-24 22:24:58 Usage end date: 2017-05-25 | 2017-04-24 22:24:58 Enabled for: Advanced Features. | 2017-04-24 22:24:58 Enabled for: Advanced Features 2. | 2017-04-24 22:24:58 Enabled for: Sierra Chart Historical Data Service. | 2017-04-24 22:24:58 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-04-24 22:24:58 Current selected Data/Trading service: DTC - Sub Instance | 2017-04-24 22:24:58 Chart Update Interval: 500 | 2017-04-24 22:24:58 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-04-24 22:24:58 2017-04-24 22:25:11 Local computer time | 2017-04-24 22:24:58 2017-04-25 03:25:11 Local computer time in UTC | 2017-04-24 22:24:58 2017-04-24 22:25:11 Local computer time in SC Time Zone | 2017-04-24 22:24:58 2017-04-25 03:25:09 Server time in UTC | 2017-04-24 22:24:58 Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-04-24 22:24:58 Program path: C:\SierraChart\SierraChartInstance_2\ | 2017-04-24 22:24:58 Data Files path: C:\SierraChart\SierraChartInstance_2\Data\ | 2017-04-24 22:24:58 OS Version Number: 6.2 | 2017-04-24 22:24:58 Locale Setting: C | 2017-04-24 22:24:58 Date Time Of Last Edit: 2017-04-25 09:40:13
[2017-04-25 04:32:19] |
Regarding the connection problem to Rithmic, we need to see the Message Log. Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-25 09:21:41] |
Reading Internal Order ID file. | 2017-04-24 22:24:58 Reading Trade Orders file. | 2017-04-24 22:24:58 Reading Trade Positions file. | 2017-04-24 22:24:58 Listening on UDP port 22903. | 2017-04-24 22:24:58 Software version: 1547 | 2017-04-24 22:24:58 Uses New Spreadsheets | 2017-04-24 22:24:58 Usage end date: 2017-05-25 | 2017-04-24 22:24:58 Enabled for: Advanced Features. | 2017-04-24 22:24:58 Enabled for: Advanced Features 2. | 2017-04-24 22:24:58 Enabled for: Sierra Chart Historical Data Service. | 2017-04-24 22:24:58 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-04-24 22:24:58 Current selected Data/Trading service: DTC - Sub Instance | 2017-04-24 22:24:58 Chart Update Interval: 500 | 2017-04-24 22:24:58 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-04-24 22:24:58 2017-04-24 22:25:11 Local computer time | 2017-04-24 22:24:58 2017-04-25 03:25:11 Local computer time in UTC | 2017-04-24 22:24:58 2017-04-24 22:25:11 Local computer time in SC Time Zone | 2017-04-24 22:24:58 2017-04-25 03:25:09 Server time in UTC | 2017-04-24 22:24:58 Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-04-24 22:24:58 Program path: C:\SierraChart\SierraChartInstance_2\ | 2017-04-24 22:24:58 Data Files path: C:\SierraChart\SierraChartInstance_2\Data\ | 2017-04-24 22:24:58 OS Version Number: 6.2 | 2017-04-24 22:24:58 Locale Setting: C | 2017-04-24 22:24:58 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:52:30 DTC Client (384) | Creating socket. | 2017-04-25 03:52:30 DTC Client (384) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:52:31 * DTC Client (384) | Initiating close of socket by core. | 2017-04-25 03:52:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:52:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:52:31 DTC Client (384) | Closed. | 2017-04-25 03:52:31 DTC - Sub Instance | Disconnected. | 2017-04-25 03:52:31 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:52:31 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:54:31 DTC Client (386) | Creating socket. | 2017-04-25 03:54:31 DTC Client (386) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:54:32 * DTC Client (386) | Initiating close of socket by core. | 2017-04-25 03:54:32 DTC Client (386) | Closed. | 2017-04-25 03:54:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:54:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:54:32 DTC - Sub Instance | Disconnected. | 2017-04-25 03:54:32 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:54:32 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:56:32 DTC Client (388) | Creating socket. | 2017-04-25 03:56:32 DTC Client (388) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:56:33 * DTC Client (388) | Initiating close of socket by core. | 2017-04-25 03:56:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:56:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:56:33 DTC Client (388) | Closed. | 2017-04-25 03:56:33 DTC - Sub Instance | Disconnected. | 2017-04-25 03:56:33 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:56:33 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:58:33 DTC Client (390) | Creating socket. | 2017-04-25 03:58:33 DTC Client (390) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:58:34 * DTC Client (390) | Initiating close of socket by core. | 2017-04-25 03:58:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:58:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:58:34 DTC Client (390) | Closed. | 2017-04-25 03:58:34 DTC - Sub Instance | Disconnected. | 2017-04-25 03:58:34 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:58:34 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:00:34 DTC Client (392) | Creating socket. | 2017-04-25 04:00:34 DTC Client (392) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:00:35 * DTC Client (392) | Initiating close of socket by core. | 2017-04-25 04:00:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:00:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:00:35 DTC Client (392) | Closed. | 2017-04-25 04:00:35 DTC - Sub Instance | Disconnected. | 2017-04-25 04:00:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:00:35 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:02:35 DTC Client (394) | Creating socket. | 2017-04-25 04:02:35 DTC Client (394) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:02:36 * DTC Client (394) | Initiating close of socket by core. | 2017-04-25 04:02:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:02:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:02:36 DTC Client (394) | Closed. | 2017-04-25 04:02:36 DTC - Sub Instance | Disconnected. | 2017-04-25 04:02:36 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:02:36 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:04:36 DTC Client (396) | Creating socket. | 2017-04-25 04:04:36 DTC Client (396) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:04:37 * DTC Client (396) | Initiating close of socket by core. | 2017-04-25 04:04:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:04:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:04:37 DTC Client (396) | Closed. | 2017-04-25 04:04:37 DTC - Sub Instance | Disconnected. | 2017-04-25 04:04:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:04:37 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:06:37 DTC Client (398) | Creating socket. | 2017-04-25 04:06:37 DTC Client (398) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:06:38 * DTC Client (398) | Initiating close of socket by core. | 2017-04-25 04:06:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:06:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:06:38 DTC Client (398) | Closed. | 2017-04-25 04:06:38 DTC - Sub Instance | Disconnected. | 2017-04-25 04:06:38 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:06:38 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:08:38 DTC Client (400) | Creating socket. | 2017-04-25 04:08:38 DTC Client (400) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:08:39 * DTC Client (400) | Initiating close of socket by core. | 2017-04-25 04:08:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:08:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:08:39 DTC Client (400) | Closed. | 2017-04-25 04:08:39 DTC - Sub Instance | Disconnected. | 2017-04-25 04:08:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:08:39 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:10:39 DTC Client (402) | Creating socket. | 2017-04-25 04:10:39 DTC Client (402) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:10:40 * DTC Client (402) | Initiating close of socket by core. | 2017-04-25 04:10:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:10:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:10:40 DTC Client (402) | Closed. | 2017-04-25 04:10:40 DTC - Sub Instance | Disconnected. | 2017-04-25 04:10:40 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:10:40 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:12:40 DTC Client (404) | Creating socket. | 2017-04-25 04:12:40 DTC Client (404) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:12:41 * DTC Client (404) | Initiating close of socket by core. | 2017-04-25 04:12:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:12:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:12:41 DTC Client (404) | Closed. | 2017-04-25 04:12:41 DTC - Sub Instance | Disconnected. | 2017-04-25 04:12:41 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:12:41 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:14:41 DTC Client (406) | Creating socket. | 2017-04-25 04:14:41 DTC Client (406) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:14:43 * DTC Client (406) | Initiating close of socket by core. | 2017-04-25 04:14:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:14:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:14:43 DTC Client (406) | Closed. | 2017-04-25 04:14:43 DTC - Sub Instance | Disconnected. | 2017-04-25 04:14:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:14:43 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:16:42 DTC Client (408) | Creating socket. | 2017-04-25 04:16:42 DTC Client (408) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:16:43 * DTC Client (408) | Initiating close of socket by core. | 2017-04-25 04:16:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:16:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:16:43 DTC Client (408) | Closed. | 2017-04-25 04:16:43 DTC - Sub Instance | Disconnected. | 2017-04-25 04:16:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:16:43 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:18:43 DTC Client (410) | Creating socket. | 2017-04-25 04:18:43 DTC Client (410) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:18:45 * DTC Client (410) | Initiating close of socket by core. | 2017-04-25 04:18:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:18:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:18:45 DTC Client (410) | Closed. | 2017-04-25 04:18:45 DTC - Sub Instance | Disconnected. | 2017-04-25 04:18:45 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:18:45 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:20:45 DTC Client (412) | Creating socket. | 2017-04-25 04:20:45 DTC Client (412) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:20:46 * DTC Client (412) | Initiating close of socket by core. | 2017-04-25 04:20:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:20:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:20:46 DTC Client (412) | Closed. | 2017-04-25 04:20:46 DTC - Sub Instance | Disconnected. | 2017-04-25 04:20:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:20:46 Date Time Of Last Edit: 2017-04-25 09:40:49
[2017-04-25 09:43:20] |
This Message Log shows a connection problem to the main instance of Sierra Chart from a sub instance: Program path: C:\SierraChart\SierraChartInstance_2\ | 2017-04-24 22:24:58 At this point, we are not going to provide any help with a sub instance of Sierra Chart. Exit from all copies of Sierra Chart on your system. And then start Sierra Chart again and do not use File >> New Instance. That is something completely separate that we will not get involved with right now. We want to help you get connected to Rithmic first. Follow through the Rithmic setup instructions here: Rithmic Trading Platform Service: Setup Instructions And if you have trouble connecting provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog And once again avoid using File >> New Instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-25 09:44:05
[2017-04-25 09:46:04] |
message log as requesteReading Internal Order ID file. | 2017-04-24 22:24:58 Reading Trade Orders file. | 2017-04-24 22:24:58 Reading Trade Positions file. | 2017-04-24 22:24:58 Listening on UDP port 22903. | 2017-04-24 22:24:58 Software version: 1547 | 2017-04-24 22:24:58 Uses New Spreadsheets | 2017-04-24 22:24:58 Usage end date: 2017-05-25 | 2017-04-24 22:24:58 Enabled for: Advanced Features. | 2017-04-24 22:24:58 Enabled for: Advanced Features 2. | 2017-04-24 22:24:58 Enabled for: Sierra Chart Historical Data Service. | 2017-04-24 22:24:58 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-04-24 22:24:58 Current selected Data/Trading service: DTC - Sub Instance | 2017-04-24 22:24:58 Chart Update Interval: 500 | 2017-04-24 22:24:58 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-04-24 22:24:58 2017-04-24 22:25:11 Local computer time | 2017-04-24 22:24:58 2017-04-25 03:25:11 Local computer time in UTC | 2017-04-24 22:24:58 2017-04-24 22:25:11 Local computer time in SC Time Zone | 2017-04-24 22:24:58 2017-04-25 03:25:09 Server time in UTC | 2017-04-24 22:24:58 Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-04-24 22:24:58 Program path: C:\SierraChart\SierraChartInstance_2\ | 2017-04-24 22:24:58 Data Files path: C:\SierraChart\SierraChartInstance_2\Data\ | 2017-04-24 22:24:58 OS Version Number: 6.2 | 2017-04-24 22:24:58 Locale Setting: C | 2017-04-24 22:24:58 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:16 DTC Client (3) | Creating socket. | 2017-04-24 22:25:16 DTC Client (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:17 * DTC Client (3) | Initiating close of socket by core. | 2017-04-24 22:25:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:17 DTC Client (3) | Closed. | 2017-04-24 22:25:17 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:17 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:20 DTC Client (4) | Creating socket. | 2017-04-24 22:25:20 DTC Client (4) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:21 * DTC Client (4) | Initiating close of socket by core. | 2017-04-24 22:25:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:21 DTC Client (4) | Closed. | 2017-04-24 22:25:21 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:21 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:21 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:24 DTC Client (5) | Creating socket. | 2017-04-24 22:25:24 DTC Client (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:25 * DTC Client (5) | Initiating close of socket by core. | 2017-04-24 22:25:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:25 DTC Client (5) | Closed. | 2017-04-24 22:25:25 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:25 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:28 DTC Client (6) | Creating socket. | 2017-04-24 22:25:28 DTC Client (6) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:29 * DTC Client (6) | Initiating close of socket by core. | 2017-04-24 22:25:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:29 DTC Client (6) | Closed. | 2017-04-24 22:25:29 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:29 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:32 DTC Client (7) | Creating socket. | 2017-04-24 22:25:32 DTC Client (7) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:33 * DTC Client (7) | Initiating close of socket by core. | 2017-04-24 22:25:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:33 DTC Client (7) | Closed. | 2017-04-24 22:25:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:33 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:33 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:36 DTC Client (8) | Creating socket. | 2017-04-24 22:25:36 DTC Client (8) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:37 * DTC Client (8) | Initiating close of socket by core. | 2017-04-24 22:25:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:37 DTC Client (8) | Closed. | 2017-04-24 22:25:37 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:37 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:40 DTC Client (9) | Creating socket. | 2017-04-24 22:25:40 DTC Client (9) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:41 * DTC Client (9) | Initiating close of socket by core. | 2017-04-24 22:25:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:41 DTC Client (9) | Closed. | 2017-04-24 22:25:41 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:41 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:44 DTC Client (10) | Creating socket. | 2017-04-24 22:25:44 DTC Client (10) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:45 * DTC Client (10) | Initiating close of socket by core. | 2017-04-24 22:25:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:45 DTC Client (10) | Closed. | 2017-04-24 22:25:45 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:45 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:45 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:48 DTC Client (11) | Creating socket. | 2017-04-24 22:25:48 DTC Client (11) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:49 * DTC Client (11) | Initiating close of socket by core. | 2017-04-24 22:25:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:49 DTC Client (11) | Closed. | 2017-04-24 22:25:49 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:49 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:52 DTC Client (12) | Creating socket. | 2017-04-24 22:25:52 DTC Client (12) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:53 * DTC Client (12) | Initiating close of socket by core. | 2017-04-24 22:25:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:53 DTC Client (12) | Closed. | 2017-04-24 22:25:53 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:53 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:25:57 DTC Client (13) | Creating socket. | 2017-04-24 22:25:57 DTC Client (13) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:25:58 * DTC Client (13) | Initiating close of socket by core. | 2017-04-24 22:25:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:25:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:25:58 DTC Client (13) | Closed. | 2017-04-24 22:25:58 DTC - Sub Instance | Disconnected. | 2017-04-24 22:25:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:25:58 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:01 DTC Client (14) | Creating socket. | 2017-04-24 22:26:01 DTC Client (14) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:02 * DTC Client (14) | Initiating close of socket by core. | 2017-04-24 22:26:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:02 DTC Client (14) | Closed. | 2017-04-24 22:26:02 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:02 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:05 DTC Client (15) | Creating socket. | 2017-04-24 22:26:05 DTC Client (15) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:06 * DTC Client (15) | Initiating close of socket by core. | 2017-04-24 22:26:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:06 DTC Client (15) | Closed. | 2017-04-24 22:26:06 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:06 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:09 DTC Client (16) | Creating socket. | 2017-04-24 22:26:09 DTC Client (16) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:10 * DTC Client (16) | Initiating close of socket by core. | 2017-04-24 22:26:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:10 DTC Client (16) | Closed. | 2017-04-24 22:26:10 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:10 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:13 DTC Client (17) | Creating socket. | 2017-04-24 22:26:13 DTC Client (17) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:14 * DTC Client (17) | Initiating close of socket by core. | 2017-04-24 22:26:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:14 DTC Client (17) | Closed. | 2017-04-24 22:26:14 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:14 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:17 DTC Client (18) | Creating socket. | 2017-04-24 22:26:17 DTC Client (18) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:18 * DTC Client (18) | Initiating close of socket by core. | 2017-04-24 22:26:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:18 DTC Client (18) | Closed. | 2017-04-24 22:26:18 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:18 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:21 DTC Client (19) | Creating socket. | 2017-04-24 22:26:21 DTC Client (19) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:22 * DTC Client (19) | Initiating close of socket by core. | 2017-04-24 22:26:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:22 DTC Client (19) | Closed. | 2017-04-24 22:26:22 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:22 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:25 DTC Client (20) | Creating socket. | 2017-04-24 22:26:25 DTC Client (20) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:26 * DTC Client (20) | Initiating close of socket by core. | 2017-04-24 22:26:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:26 DTC Client (20) | Closed. | 2017-04-24 22:26:26 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:26 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:29 DTC Client (21) | Creating socket. | 2017-04-24 22:26:29 DTC Client (21) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:30 * DTC Client (21) | Initiating close of socket by core. | 2017-04-24 22:26:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:30 DTC Client (21) | Closed. | 2017-04-24 22:26:30 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:30 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:33 DTC Client (22) | Creating socket. | 2017-04-24 22:26:33 DTC Client (22) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:34 * DTC Client (22) | Initiating close of socket by core. | 2017-04-24 22:26:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:34 DTC Client (22) | Closed. | 2017-04-24 22:26:34 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:34 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:37 DTC Client (23) | Creating socket. | 2017-04-24 22:26:37 DTC Client (23) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:38 * DTC Client (23) | Initiating close of socket by core. | 2017-04-24 22:26:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:38 DTC Client (23) | Closed. | 2017-04-24 22:26:38 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:38 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:41 DTC Client (24) | Creating socket. | 2017-04-24 22:26:41 DTC Client (24) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:42 * DTC Client (24) | Initiating close of socket by core. | 2017-04-24 22:26:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:42 DTC Client (24) | Closed. | 2017-04-24 22:26:42 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:42 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:45 DTC Client (25) | Creating socket. | 2017-04-24 22:26:45 DTC Client (25) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:46 * DTC Client (25) | Initiating close of socket by core. | 2017-04-24 22:26:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:46 DTC Client (25) | Closed. | 2017-04-24 22:26:46 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:46 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:49 DTC Client (26) | Creating socket. | 2017-04-24 22:26:49 DTC Client (26) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:50 * DTC Client (26) | Initiating close of socket by core. | 2017-04-24 22:26:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:50 DTC Client (26) | Closed. | 2017-04-24 22:26:50 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:50 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:53 DTC Client (27) | Creating socket. | 2017-04-24 22:26:53 DTC Client (27) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:54 * DTC Client (27) | Initiating close of socket by core. | 2017-04-24 22:26:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:54 DTC Client (27) | Closed. | 2017-04-24 22:26:54 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:54 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:26:57 DTC Client (28) | Creating socket. | 2017-04-24 22:26:57 DTC Client (28) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:26:58 * DTC Client (28) | Initiating close of socket by core. | 2017-04-24 22:26:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:26:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:26:58 DTC Client (28) | Closed. | 2017-04-24 22:26:58 DTC - Sub Instance | Disconnected. | 2017-04-24 22:26:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:26:58 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:01 DTC Client (29) | Creating socket. | 2017-04-24 22:27:01 DTC Client (29) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:02 * DTC Client (29) | Initiating close of socket by core. | 2017-04-24 22:27:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:02 DTC Client (29) | Closed. | 2017-04-24 22:27:02 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:02 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:05 DTC Client (30) | Creating socket. | 2017-04-24 22:27:05 DTC Client (30) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:06 * DTC Client (30) | Initiating close of socket by core. | 2017-04-24 22:27:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:06 DTC Client (30) | Closed. | 2017-04-24 22:27:06 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:06 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:10 DTC Client (31) | Creating socket. | 2017-04-24 22:27:10 DTC Client (31) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:11 * DTC Client (31) | Initiating close of socket by core. | 2017-04-24 22:27:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:11 DTC Client (31) | Closed. | 2017-04-24 22:27:11 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:11 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:14 DTC Client (33) | Creating socket. | 2017-04-24 22:27:14 DTC Client (33) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:15 * DTC Client (33) | Initiating close of socket by core. | 2017-04-24 22:27:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:15 DTC Client (33) | Closed. | 2017-04-24 22:27:15 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:15 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:18 DTC Client (34) | Creating socket. | 2017-04-24 22:27:18 DTC Client (34) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:19 * DTC Client (34) | Initiating close of socket by core. | 2017-04-24 22:27:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:19 DTC Client (34) | Closed. | 2017-04-24 22:27:19 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:19 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:22 DTC Client (35) | Creating socket. | 2017-04-24 22:27:22 DTC Client (35) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:23 * DTC Client (35) | Initiating close of socket by core. | 2017-04-24 22:27:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:23 DTC Client (35) | Closed. | 2017-04-24 22:27:23 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:23 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:26 DTC Client (36) | Creating socket. | 2017-04-24 22:27:26 DTC Client (36) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:27 * DTC Client (36) | Initiating close of socket by core. | 2017-04-24 22:27:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:27 DTC Client (36) | Closed. | 2017-04-24 22:27:27 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:27 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:30 DTC Client (37) | Creating socket. | 2017-04-24 22:27:30 DTC Client (37) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:31 * DTC Client (37) | Initiating close of socket by core. | 2017-04-24 22:27:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:31 DTC Client (37) | Closed. | 2017-04-24 22:27:31 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:31 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:34 DTC Client (38) | Creating socket. | 2017-04-24 22:27:34 DTC Client (38) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:35 * DTC Client (38) | Initiating close of socket by core. | 2017-04-24 22:27:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:35 DTC Client (38) | Closed. | 2017-04-24 22:27:35 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:35 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:38 DTC Client (39) | Creating socket. | 2017-04-24 22:27:38 DTC Client (39) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:39 * DTC Client (39) | Initiating close of socket by core. | 2017-04-24 22:27:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:39 DTC Client (39) | Closed. | 2017-04-24 22:27:39 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:39 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:42 DTC Client (40) | Creating socket. | 2017-04-24 22:27:42 DTC Client (40) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:43 * DTC Client (40) | Initiating close of socket by core. | 2017-04-24 22:27:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:43 DTC Client (40) | Closed. | 2017-04-24 22:27:43 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:43 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:46 DTC Client (41) | Creating socket. | 2017-04-24 22:27:46 DTC Client (41) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:47 * DTC Client (41) | Initiating close of socket by core. | 2017-04-24 22:27:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:47 DTC Client (41) | Closed. | 2017-04-24 22:27:47 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:47 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:50 DTC Client (42) | Creating socket. | 2017-04-24 22:27:50 DTC Client (42) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:51 * DTC Client (42) | Initiating close of socket by core. | 2017-04-24 22:27:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:51 DTC Client (42) | Closed. | 2017-04-24 22:27:51 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:51 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:54 DTC Client (43) | Creating socket. | 2017-04-24 22:27:54 DTC Client (43) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:55 * DTC Client (43) | Initiating close of socket by core. | 2017-04-24 22:27:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:55 DTC Client (43) | Closed. | 2017-04-24 22:27:55 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:55 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:27:58 DTC Client (44) | Creating socket. | 2017-04-24 22:27:58 DTC Client (44) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:27:59 * DTC Client (44) | Initiating close of socket by core. | 2017-04-24 22:27:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:27:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:27:59 DTC Client (44) | Closed. | 2017-04-24 22:27:59 DTC - Sub Instance | Disconnected. | 2017-04-24 22:27:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:27:59 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:02 DTC Client (45) | Creating socket. | 2017-04-24 22:28:02 DTC Client (45) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:03 * DTC Client (45) | Initiating close of socket by core. | 2017-04-24 22:28:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:03 DTC Client (45) | Closed. | 2017-04-24 22:28:03 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:03 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:06 DTC Client (46) | Creating socket. | 2017-04-24 22:28:06 DTC Client (46) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:07 * DTC Client (46) | Initiating close of socket by core. | 2017-04-24 22:28:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:07 DTC Client (46) | Closed. | 2017-04-24 22:28:07 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:07 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:10 DTC Client (47) | Creating socket. | 2017-04-24 22:28:10 DTC Client (47) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:11 * DTC Client (47) | Initiating close of socket by core. | 2017-04-24 22:28:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:11 DTC Client (47) | Closed. | 2017-04-24 22:28:11 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:11 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:14 DTC Client (48) | Creating socket. | 2017-04-24 22:28:14 DTC Client (48) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:15 * DTC Client (48) | Initiating close of socket by core. | 2017-04-24 22:28:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:15 DTC Client (48) | Closed. | 2017-04-24 22:28:15 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:15 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:18 DTC Client (49) | Creating socket. | 2017-04-24 22:28:18 DTC Client (49) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:19 * DTC Client (49) | Initiating close of socket by core. | 2017-04-24 22:28:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:19 DTC Client (49) | Closed. | 2017-04-24 22:28:19 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:19 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:22 DTC Client (50) | Creating socket. | 2017-04-24 22:28:22 DTC Client (50) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:24 * DTC Client (50) | Initiating close of socket by core. | 2017-04-24 22:28:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:24 DTC Client (50) | Closed. | 2017-04-24 22:28:24 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:24 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:27 DTC Client (51) | Creating socket. | 2017-04-24 22:28:27 DTC Client (51) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:28 * DTC Client (51) | Initiating close of socket by core. | 2017-04-24 22:28:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:28 DTC Client (51) | Closed. | 2017-04-24 22:28:28 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:28 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:31 DTC Client (52) | Creating socket. | 2017-04-24 22:28:31 DTC Client (52) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:32 * DTC Client (52) | Initiating close of socket by core. | 2017-04-24 22:28:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:32 DTC Client (52) | Closed. | 2017-04-24 22:28:32 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:32 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:28:35 DTC Client (53) | Creating socket. | 2017-04-24 22:28:35 DTC Client (53) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:28:36 * DTC Client (53) | Initiating close of socket by core. | 2017-04-24 22:28:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:28:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:28:36 DTC Client (53) | Closed. | 2017-04-24 22:28:36 DTC - Sub Instance | Disconnected. | 2017-04-24 22:28:36 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:28:36 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:30:36 DTC Client (55) | Creating socket. | 2017-04-24 22:30:36 DTC Client (55) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:30:37 * DTC Client (55) | Initiating close of socket by core. | 2017-04-24 22:30:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:30:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:30:37 DTC Client (55) | Closed. | 2017-04-24 22:30:37 DTC - Sub Instance | Disconnected. | 2017-04-24 22:30:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:30:37 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:32:37 DTC Client (57) | Creating socket. | 2017-04-24 22:32:37 DTC Client (57) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:32:38 * DTC Client (57) | Initiating close of socket by core. | 2017-04-24 22:32:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:32:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:32:38 DTC Client (57) | Closed. | 2017-04-24 22:32:38 DTC - Sub Instance | Disconnected. | 2017-04-24 22:32:38 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:32:38 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:34:38 DTC Client (59) | Creating socket. | 2017-04-24 22:34:38 DTC Client (59) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:34:39 * DTC Client (59) | Initiating close of socket by core. | 2017-04-24 22:34:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:34:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:34:39 DTC Client (59) | Closed. | 2017-04-24 22:34:39 DTC - Sub Instance | Disconnected. | 2017-04-24 22:34:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:34:39 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:36:39 DTC Client (61) | Creating socket. | 2017-04-24 22:36:39 DTC Client (61) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:36:40 * DTC Client (61) | Initiating close of socket by core. | 2017-04-24 22:36:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:36:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:36:40 DTC Client (61) | Closed. | 2017-04-24 22:36:40 DTC - Sub Instance | Disconnected. | 2017-04-24 22:36:40 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:36:40 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:37:34 DTC Client (63) | Creating socket. | 2017-04-24 22:37:34 DTC Client (63) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:37:35 * DTC Client (63) | Initiating close of socket by core. | 2017-04-24 22:37:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:37:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:37:35 DTC Client (63) | Closed. | 2017-04-24 22:37:35 DTC - Sub Instance | Disconnected. | 2017-04-24 22:37:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:37:35 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:39:35 DTC Client (65) | Creating socket. | 2017-04-24 22:39:35 DTC Client (65) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:39:36 * DTC Client (65) | Initiating close of socket by core. | 2017-04-24 22:39:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:39:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:39:36 DTC Client (65) | Closed. | 2017-04-24 22:39:36 DTC - Sub Instance | Disconnected. | 2017-04-24 22:39:36 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:39:36 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:41:36 DTC Client (67) | Creating socket. | 2017-04-24 22:41:36 DTC Client (67) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:41:37 * DTC Client (67) | Initiating close of socket by core. | 2017-04-24 22:41:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:41:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:41:37 DTC Client (67) | Closed. | 2017-04-24 22:41:37 DTC - Sub Instance | Disconnected. | 2017-04-24 22:41:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:41:37 YMM7-CBOT #1 | Reloading chart. | 2017-04-24 22:41:42 Intraday data recording state for symbol YMM7-CBOT is set to download 'Pending'. | 2017-04-24 22:41:43 HD Request # 2 | Downloading Intraday chart data for YMM7-CBOT to the file YMM7-CBOT.scid. Service: DTCSubInstance | 2017-04-24 22:41:43 Compressing file: C:\SierraChart\SierraChartInstance_2\Data\YMM7-CBOT.scid. This may take a while. | 2017-04-24 22:41:43 HD Request # 2 | Download start date-time: 2016-10-20 22:41:42.000 | 2017-04-24 22:41:43 HD Request # 2 | Using server: 127.0.0.1 port 11098 | 2017-04-24 22:41:43 Socket (68) | Creating socket. | 2017-04-24 22:41:43 Socket (68) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:41:44 * Socket (68) | Initiating close of socket by core. | 2017-04-24 22:41:44 Socket (68) | Closed. | 2017-04-24 22:41:44 HD Request # 2 | Error downloading historical Intraday data for YMM7-CBOT. The network socket has been closed. Retrying download. | 2017-04-24 22:41:44 Historical data download thread signaled to stop. | 2017-04-24 22:41:44 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMM7-CBOT | 2017-04-24 22:41:44 HD Request # 3 | Downloading Intraday chart data for YMM7-CBOT to the file YMM7-CBOT.scid. Service: DTCSubInstance | 2017-04-24 22:41:44 HD Request # 3 | Download start date-time: 2016-10-20 22:41:43.000 | 2017-04-24 22:41:44 HD Request # 3 | Using server: 127.0.0.1 port 11098 | 2017-04-24 22:41:44 Socket (69) | Creating socket. | 2017-04-24 22:41:44 Socket (69) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:41:45 * Socket (69) | Initiating close of socket by core. | 2017-04-24 22:41:45 Socket (69) | Closed. | 2017-04-24 22:41:45 HD Request # 3 | Error downloading historical Intraday data for YMM7-CBOT. The network socket has been closed. Retrying download. | 2017-04-24 22:41:45 Historical data download thread signaled to stop. | 2017-04-24 22:41:45 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMM7-CBOT | 2017-04-24 22:41:45 HD Request # 4 | Downloading Intraday chart data for YMM7-CBOT to the file YMM7-CBOT.scid. Service: DTCSubInstance | 2017-04-24 22:41:45 HD Request # 4 | Download start date-time: 2016-10-20 22:41:44.000 | 2017-04-24 22:41:45 HD Request # 4 | Using server: 127.0.0.1 port 11098 | 2017-04-24 22:41:45 Socket (70) | Creating socket. | 2017-04-24 22:41:45 Socket (70) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:41:46 * Socket (70) | Initiating close of socket by core. | 2017-04-24 22:41:46 Socket (70) | Closed. | 2017-04-24 22:41:46 HD Request # 4 | Error downloading historical Intraday data for YMM7-CBOT. The network socket has been closed. Retrying download. | 2017-04-24 22:41:46 Historical data download thread signaled to stop. | 2017-04-24 22:41:46 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMM7-CBOT | 2017-04-24 22:41:46 HD Request # 4 | Intraday download COMPLETE for YMM7-CBOT. Completion time: 1s. Unique request ID: 1 | 2017-04-24 22:41:46 Removed historical data download ID 1 | 2017-04-24 22:41:46 YMM7-CBOT 1 Min #2 | Reloading chart. | 2017-04-24 22:42:28 YMM7-CBOT 1 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartInstance_2\Data\YMM7-CBOT.scid | 2017-04-24 22:42:28 YMM7-CBOT #3 | Reloading chart. | 2017-04-24 22:42:49 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:43:37 DTC Client (72) | Creating socket. | 2017-04-24 22:43:37 DTC Client (72) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:43:38 * DTC Client (72) | Initiating close of socket by core. | 2017-04-24 22:43:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:43:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:43:38 DTC Client (72) | Closed. | 2017-04-24 22:43:38 DTC - Sub Instance | Disconnected. | 2017-04-24 22:43:38 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:43:38 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:45:38 DTC Client (74) | Creating socket. | 2017-04-24 22:45:38 DTC Client (74) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:45:42 * DTC Client (74) | Initiating close of socket by core. | 2017-04-24 22:45:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:45:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:45:42 DTC Client (74) | Closed. | 2017-04-24 22:45:42 DTC - Sub Instance | Disconnected. | 2017-04-24 22:45:42 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:45:42 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:47:41 DTC Client (76) | Creating socket. | 2017-04-24 22:47:41 DTC Client (76) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:47:42 * DTC Client (76) | Initiating close of socket by core. | 2017-04-24 22:47:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:47:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:47:42 DTC Client (76) | Closed. | 2017-04-24 22:47:42 DTC - Sub Instance | Disconnected. | 2017-04-24 22:47:42 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:47:42 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:49:42 DTC Client (78) | Creating socket. | 2017-04-24 22:49:42 DTC Client (78) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:49:43 * DTC Client (78) | Initiating close of socket by core. | 2017-04-24 22:49:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:49:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:49:43 DTC Client (78) | Closed. | 2017-04-24 22:49:43 DTC - Sub Instance | Disconnected. | 2017-04-24 22:49:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:49:43 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:51:43 DTC Client (80) | Creating socket. | 2017-04-24 22:51:43 DTC Client (80) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:51:45 * DTC Client (80) | Initiating close of socket by core. | 2017-04-24 22:51:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:51:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:51:45 DTC Client (80) | Closed. | 2017-04-24 22:51:45 DTC - Sub Instance | Disconnected. | 2017-04-24 22:51:45 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:51:45 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:53:44 DTC Client (82) | Creating socket. | 2017-04-24 22:53:44 DTC Client (82) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:53:45 * DTC Client (82) | Initiating close of socket by core. | 2017-04-24 22:53:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:53:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:53:45 DTC Client (82) | Closed. | 2017-04-24 22:53:45 DTC - Sub Instance | Disconnected. | 2017-04-24 22:53:45 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:53:45 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:55:46 DTC Client (84) | Creating socket. | 2017-04-24 22:55:46 DTC Client (84) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:55:47 * DTC Client (84) | Initiating close of socket by core. | 2017-04-24 22:55:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:55:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:55:47 DTC Client (84) | Closed. | 2017-04-24 22:55:47 DTC - Sub Instance | Disconnected. | 2017-04-24 22:55:47 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:55:47 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:57:46 DTC Client (86) | Creating socket. | 2017-04-24 22:57:46 DTC Client (86) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:57:47 * DTC Client (86) | Initiating close of socket by core. | 2017-04-24 22:57:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:57:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:57:47 DTC Client (86) | Closed. | 2017-04-24 22:57:47 DTC - Sub Instance | Disconnected. | 2017-04-24 22:57:47 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:57:47 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 22:59:48 DTC Client (88) | Creating socket. | 2017-04-24 22:59:48 DTC Client (88) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 22:59:49 * DTC Client (88) | Initiating close of socket by core. | 2017-04-24 22:59:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 22:59:49 DTC Client (88) | Closed. | 2017-04-24 22:59:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 22:59:49 DTC - Sub Instance | Disconnected. | 2017-04-24 22:59:49 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 22:59:49 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:01:49 DTC Client (90) | Creating socket. | 2017-04-24 23:01:49 DTC Client (90) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:01:50 * DTC Client (90) | Initiating close of socket by core. | 2017-04-24 23:01:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:01:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:01:50 DTC Client (90) | Closed. | 2017-04-24 23:01:50 DTC - Sub Instance | Disconnected. | 2017-04-24 23:01:50 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:01:50 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:03:50 DTC Client (92) | Creating socket. | 2017-04-24 23:03:50 DTC Client (92) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:03:51 * DTC Client (92) | Initiating close of socket by core. | 2017-04-24 23:03:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:03:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:03:51 DTC Client (92) | Closed. | 2017-04-24 23:03:51 DTC - Sub Instance | Disconnected. | 2017-04-24 23:03:51 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:03:51 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:05:51 DTC Client (94) | Creating socket. | 2017-04-24 23:05:51 DTC Client (94) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:05:52 * DTC Client (94) | Initiating close of socket by core. | 2017-04-24 23:05:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:05:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:05:52 DTC Client (94) | Closed. | 2017-04-24 23:05:52 DTC - Sub Instance | Disconnected. | 2017-04-24 23:05:52 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:05:52 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:07:52 DTC Client (96) | Creating socket. | 2017-04-24 23:07:52 DTC Client (96) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:07:53 * DTC Client (96) | Initiating close of socket by core. | 2017-04-24 23:07:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:07:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:07:53 DTC Client (96) | Closed. | 2017-04-24 23:07:53 DTC - Sub Instance | Disconnected. | 2017-04-24 23:07:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:07:53 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:09:53 DTC Client (98) | Creating socket. | 2017-04-24 23:09:53 DTC Client (98) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:09:54 * DTC Client (98) | Initiating close of socket by core. | 2017-04-24 23:09:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:09:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:09:54 DTC Client (98) | Closed. | 2017-04-24 23:09:54 DTC - Sub Instance | Disconnected. | 2017-04-24 23:09:54 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:09:54 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:11:54 DTC Client (100) | Creating socket. | 2017-04-24 23:11:54 DTC Client (100) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:11:55 * DTC Client (100) | Initiating close of socket by core. | 2017-04-24 23:11:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:11:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:11:55 DTC Client (100) | Closed. | 2017-04-24 23:11:55 DTC - Sub Instance | Disconnected. | 2017-04-24 23:11:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:11:55 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:13:55 DTC Client (102) | Creating socket. | 2017-04-24 23:13:55 DTC Client (102) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:13:56 * DTC Client (102) | Initiating close of socket by core. | 2017-04-24 23:13:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:13:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:13:56 DTC Client (102) | Closed. | 2017-04-24 23:13:56 DTC - Sub Instance | Disconnected. | 2017-04-24 23:13:56 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:13:56 A request for the latest software update has been made. | 2017-04-24 23:14:15 * The update is being downloaded in the background. When it is complete, you will be prompted. | 2017-04-24 23:14:15 * HTTPS connection to www.sierrachart.com:443 (103) | Creating socket. Using TLS 1.2. | 2017-04-24 23:14:15 Download for software update has been redirected. Request ID: 1 -> 2 | 2017-04-24 23:14:15 HTTP connection to www.sierrachart.com:80 (104) | Creating socket. | 2017-04-24 23:14:15 HTTPS connection to www.sierrachart.com:443 (103) | Socket gracefully closed by remote side. | 2017-04-24 23:14:20 HTTPS connection to www.sierrachart.com:443 (103) | Received socket Close event | 2017-04-24 23:14:20 HTTPS connection to www.sierrachart.com:443 (103) | Initiating close of socket by core. | 2017-04-24 23:14:20 HTTPS connection to www.sierrachart.com:443 (103) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-24 23:14:20 HTTPS connection to www.sierrachart.com:443 (103) | Closed. | 2017-04-24 23:14:20 File has been written to: C:\SierraChart\SierraChartInstance_2\SierraChartFileDownloader.exe. File Size: 5061120 bytes. | 2017-04-24 23:14:24 HTTP connection to www.sierrachart.com:80 (104) | Socket gracefully closed by remote side. | 2017-04-24 23:14:29 HTTP connection to www.sierrachart.com:80 (104) | Received socket Close event | 2017-04-24 23:14:29 HTTP connection to www.sierrachart.com:80 (104) | Initiating close of socket by core. | 2017-04-24 23:14:29 HTTP connection to www.sierrachart.com:80 (104) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-24 23:14:29 HTTP connection to www.sierrachart.com:80 (104) | Closed. | 2017-04-24 23:14:29 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:15:56 DTC Client (106) | Creating socket. | 2017-04-24 23:15:56 DTC Client (106) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:15:57 * DTC Client (106) | Initiating close of socket by core. | 2017-04-24 23:15:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:15:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:15:57 DTC Client (106) | Closed. | 2017-04-24 23:15:57 DTC - Sub Instance | Disconnected. | 2017-04-24 23:15:57 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:15:57 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:17:57 DTC Client (108) | Creating socket. | 2017-04-24 23:17:57 DTC Client (108) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:17:58 * DTC Client (108) | Initiating close of socket by core. | 2017-04-24 23:17:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:17:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:17:58 DTC Client (108) | Closed. | 2017-04-24 23:17:58 DTC - Sub Instance | Disconnected. | 2017-04-24 23:17:58 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:17:58 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:19:58 DTC Client (110) | Creating socket. | 2017-04-24 23:19:58 DTC Client (110) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:19:59 * DTC Client (110) | Initiating close of socket by core. | 2017-04-24 23:19:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:19:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:19:59 DTC Client (110) | Closed. | 2017-04-24 23:19:59 DTC - Sub Instance | Disconnected. | 2017-04-24 23:19:59 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:19:59 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:22:01 DTC Client (112) | Creating socket. | 2017-04-24 23:22:01 DTC Client (112) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:22:02 * DTC Client (112) | Initiating close of socket by core. | 2017-04-24 23:22:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:22:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:22:02 DTC Client (112) | Closed. | 2017-04-24 23:22:02 DTC - Sub Instance | Disconnected. | 2017-04-24 23:22:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:22:02 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:24:02 DTC Client (114) | Creating socket. | 2017-04-24 23:24:02 DTC Client (114) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:24:03 * DTC Client (114) | Initiating close of socket by core. | 2017-04-24 23:24:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:24:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:24:03 DTC Client (114) | Closed. | 2017-04-24 23:24:03 DTC - Sub Instance | Disconnected. | 2017-04-24 23:24:03 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:24:03 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:26:03 DTC Client (116) | Creating socket. | 2017-04-24 23:26:03 DTC Client (116) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:26:04 * DTC Client (116) | Initiating close of socket by core. | 2017-04-24 23:26:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:26:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:26:04 DTC Client (116) | Closed. | 2017-04-24 23:26:04 DTC - Sub Instance | Disconnected. | 2017-04-24 23:26:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:26:04 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:28:04 DTC Client (118) | Creating socket. | 2017-04-24 23:28:04 DTC Client (118) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:28:05 * DTC Client (118) | Initiating close of socket by core. | 2017-04-24 23:28:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:28:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:28:05 DTC Client (118) | Closed. | 2017-04-24 23:28:05 DTC - Sub Instance | Disconnected. | 2017-04-24 23:28:05 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:28:05 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:30:05 DTC Client (120) | Creating socket. | 2017-04-24 23:30:05 DTC Client (120) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:30:06 * DTC Client (120) | Initiating close of socket by core. | 2017-04-24 23:30:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:30:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:30:06 DTC Client (120) | Closed. | 2017-04-24 23:30:06 DTC - Sub Instance | Disconnected. | 2017-04-24 23:30:06 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:30:06 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:32:06 DTC Client (122) | Creating socket. | 2017-04-24 23:32:06 DTC Client (122) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:32:07 * DTC Client (122) | Initiating close of socket by core. | 2017-04-24 23:32:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:32:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:32:07 DTC Client (122) | Closed. | 2017-04-24 23:32:07 DTC - Sub Instance | Disconnected. | 2017-04-24 23:32:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:32:07 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:34:07 DTC Client (124) | Creating socket. | 2017-04-24 23:34:07 DTC Client (124) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:34:08 * DTC Client (124) | Initiating close of socket by core. | 2017-04-24 23:34:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:34:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:34:08 DTC Client (124) | Closed. | 2017-04-24 23:34:08 DTC - Sub Instance | Disconnected. | 2017-04-24 23:34:08 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:34:08 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:36:08 DTC Client (126) | Creating socket. | 2017-04-24 23:36:08 DTC Client (126) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:36:09 * DTC Client (126) | Initiating close of socket by core. | 2017-04-24 23:36:09 DTC Client (126) | Closed. | 2017-04-24 23:36:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:36:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:36:09 DTC - Sub Instance | Disconnected. | 2017-04-24 23:36:09 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:36:09 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:38:11 DTC Client (128) | Creating socket. | 2017-04-24 23:38:11 DTC Client (128) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:38:11 * DTC Client (128) | Initiating close of socket by core. | 2017-04-24 23:38:11 DTC Client (128) | Closed. | 2017-04-24 23:38:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:38:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:38:11 DTC - Sub Instance | Disconnected. | 2017-04-24 23:38:11 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:38:11 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:40:11 DTC Client (130) | Creating socket. | 2017-04-24 23:40:11 DTC Client (130) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:40:12 * DTC Client (130) | Initiating close of socket by core. | 2017-04-24 23:40:12 DTC Client (130) | Closed. | 2017-04-24 23:40:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:40:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:40:12 DTC - Sub Instance | Disconnected. | 2017-04-24 23:40:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:40:12 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:42:13 DTC Client (132) | Creating socket. | 2017-04-24 23:42:13 DTC Client (132) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:42:14 * DTC Client (132) | Initiating close of socket by core. | 2017-04-24 23:42:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:42:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:42:14 DTC Client (132) | Closed. | 2017-04-24 23:42:14 DTC - Sub Instance | Disconnected. | 2017-04-24 23:42:14 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:42:14 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:44:13 DTC Client (134) | Creating socket. | 2017-04-24 23:44:13 DTC Client (134) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:44:14 * DTC Client (134) | Initiating close of socket by core. | 2017-04-24 23:44:14 DTC Client (134) | Closed. | 2017-04-24 23:44:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:44:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:44:14 DTC - Sub Instance | Disconnected. | 2017-04-24 23:44:14 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:44:14 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:46:14 DTC Client (136) | Creating socket. | 2017-04-24 23:46:14 DTC Client (136) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:46:16 * DTC Client (136) | Initiating close of socket by core. | 2017-04-24 23:46:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:46:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:46:16 DTC Client (136) | Closed. | 2017-04-24 23:46:16 DTC - Sub Instance | Disconnected. | 2017-04-24 23:46:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:46:16 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:48:15 DTC Client (138) | Creating socket. | 2017-04-24 23:48:15 DTC Client (138) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:48:16 * DTC Client (138) | Initiating close of socket by core. | 2017-04-24 23:48:16 DTC Client (138) | Closed. | 2017-04-24 23:48:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:48:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:48:16 DTC - Sub Instance | Disconnected. | 2017-04-24 23:48:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:48:16 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:50:17 DTC Client (140) | Creating socket. | 2017-04-24 23:50:17 DTC Client (140) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:50:18 * DTC Client (140) | Initiating close of socket by core. | 2017-04-24 23:50:18 DTC Client (140) | Closed. | 2017-04-24 23:50:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:50:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:50:18 DTC - Sub Instance | Disconnected. | 2017-04-24 23:50:18 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:50:18 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:52:18 DTC Client (142) | Creating socket. | 2017-04-24 23:52:18 DTC Client (142) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:52:19 * DTC Client (142) | Initiating close of socket by core. | 2017-04-24 23:52:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:52:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:52:19 DTC Client (142) | Closed. | 2017-04-24 23:52:19 DTC - Sub Instance | Disconnected. | 2017-04-24 23:52:19 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:52:19 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:54:19 DTC Client (144) | Creating socket. | 2017-04-24 23:54:19 DTC Client (144) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:54:20 * DTC Client (144) | Initiating close of socket by core. | 2017-04-24 23:54:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:54:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:54:20 DTC Client (144) | Closed. | 2017-04-24 23:54:20 DTC - Sub Instance | Disconnected. | 2017-04-24 23:54:20 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:54:20 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:56:20 DTC Client (147) | Creating socket. | 2017-04-24 23:56:20 DTC Client (147) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:56:21 * DTC Client (147) | Initiating close of socket by core. | 2017-04-24 23:56:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:56:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:56:21 DTC Client (147) | Closed. | 2017-04-24 23:56:21 DTC - Sub Instance | Disconnected. | 2017-04-24 23:56:21 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:56:21 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-24 23:58:21 DTC Client (149) | Creating socket. | 2017-04-24 23:58:21 DTC Client (149) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-24 23:58:22 * DTC Client (149) | Initiating close of socket by core. | 2017-04-24 23:58:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 23:58:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 23:58:22 DTC Client (149) | Closed. | 2017-04-24 23:58:22 DTC - Sub Instance | Disconnected. | 2017-04-24 23:58:22 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 23:58:22 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:00:22 DTC Client (151) | Creating socket. | 2017-04-25 00:00:22 DTC Client (151) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:00:23 * DTC Client (151) | Initiating close of socket by core. | 2017-04-25 00:00:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:00:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:00:23 DTC Client (151) | Closed. | 2017-04-25 00:00:23 DTC - Sub Instance | Disconnected. | 2017-04-25 00:00:23 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:00:23 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:02:23 DTC Client (153) | Creating socket. | 2017-04-25 00:02:23 DTC Client (153) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:02:24 * DTC Client (153) | Initiating close of socket by core. | 2017-04-25 00:02:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:02:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:02:24 DTC Client (153) | Closed. | 2017-04-25 00:02:24 DTC - Sub Instance | Disconnected. | 2017-04-25 00:02:24 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:02:24 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:04:24 DTC Client (155) | Creating socket. | 2017-04-25 00:04:24 DTC Client (155) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:04:25 * DTC Client (155) | Initiating close of socket by core. | 2017-04-25 00:04:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:04:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:04:25 DTC Client (155) | Closed. | 2017-04-25 00:04:25 DTC - Sub Instance | Disconnected. | 2017-04-25 00:04:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:04:25 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:06:25 DTC Client (157) | Creating socket. | 2017-04-25 00:06:25 DTC Client (157) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:06:26 * DTC Client (157) | Initiating close of socket by core. | 2017-04-25 00:06:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:06:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:06:26 DTC Client (157) | Closed. | 2017-04-25 00:06:26 DTC - Sub Instance | Disconnected. | 2017-04-25 00:06:26 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:06:26 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:08:26 DTC Client (159) | Creating socket. | 2017-04-25 00:08:26 DTC Client (159) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:08:27 * DTC Client (159) | Initiating close of socket by core. | 2017-04-25 00:08:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:08:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:08:27 DTC Client (159) | Closed. | 2017-04-25 00:08:27 DTC - Sub Instance | Disconnected. | 2017-04-25 00:08:27 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:08:27 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:10:27 DTC Client (161) | Creating socket. | 2017-04-25 00:10:27 DTC Client (161) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:10:28 * DTC Client (161) | Initiating close of socket by core. | 2017-04-25 00:10:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:10:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:10:28 DTC Client (161) | Closed. | 2017-04-25 00:10:28 DTC - Sub Instance | Disconnected. | 2017-04-25 00:10:28 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:10:28 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:12:28 DTC Client (163) | Creating socket. | 2017-04-25 00:12:28 DTC Client (163) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:12:29 * DTC Client (163) | Initiating close of socket by core. | 2017-04-25 00:12:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:12:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:12:29 DTC Client (163) | Closed. | 2017-04-25 00:12:29 DTC - Sub Instance | Disconnected. | 2017-04-25 00:12:29 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:12:29 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:14:29 DTC Client (165) | Creating socket. | 2017-04-25 00:14:29 DTC Client (165) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:14:30 * DTC Client (165) | Initiating close of socket by core. | 2017-04-25 00:14:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:14:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:14:31 DTC Client (165) | Closed. | 2017-04-25 00:14:31 DTC - Sub Instance | Disconnected. | 2017-04-25 00:14:31 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:14:31 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:16:30 DTC Client (167) | Creating socket. | 2017-04-25 00:16:30 DTC Client (167) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:16:31 * DTC Client (167) | Initiating close of socket by core. | 2017-04-25 00:16:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:16:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:16:31 DTC Client (167) | Closed. | 2017-04-25 00:16:31 DTC - Sub Instance | Disconnected. | 2017-04-25 00:16:31 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:16:31 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:18:31 DTC Client (169) | Creating socket. | 2017-04-25 00:18:31 DTC Client (169) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:18:32 * DTC Client (169) | Initiating close of socket by core. | 2017-04-25 00:18:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:18:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:18:32 DTC Client (169) | Closed. | 2017-04-25 00:18:32 DTC - Sub Instance | Disconnected. | 2017-04-25 00:18:32 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:18:32 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:20:33 DTC Client (171) | Creating socket. | 2017-04-25 00:20:33 DTC Client (171) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:20:34 * DTC Client (171) | Initiating close of socket by core. | 2017-04-25 00:20:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:20:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:20:34 DTC Client (171) | Closed. | 2017-04-25 00:20:34 DTC - Sub Instance | Disconnected. | 2017-04-25 00:20:34 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:20:34 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:22:33 DTC Client (173) | Creating socket. | 2017-04-25 00:22:33 DTC Client (173) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:22:35 * DTC Client (173) | Initiating close of socket by core. | 2017-04-25 00:22:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:22:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:22:35 DTC Client (173) | Closed. | 2017-04-25 00:22:35 DTC - Sub Instance | Disconnected. | 2017-04-25 00:22:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:22:35 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:24:35 DTC Client (175) | Creating socket. | 2017-04-25 00:24:35 DTC Client (175) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:24:36 * DTC Client (175) | Initiating close of socket by core. | 2017-04-25 00:24:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:24:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:24:36 DTC Client (175) | Closed. | 2017-04-25 00:24:36 DTC - Sub Instance | Disconnected. | 2017-04-25 00:24:36 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:24:36 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:26:36 DTC Client (177) | Creating socket. | 2017-04-25 00:26:36 DTC Client (177) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:26:37 * DTC Client (177) | Initiating close of socket by core. | 2017-04-25 00:26:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:26:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:26:37 DTC Client (177) | Closed. | 2017-04-25 00:26:37 DTC - Sub Instance | Disconnected. | 2017-04-25 00:26:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:26:37 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:28:37 DTC Client (179) | Creating socket. | 2017-04-25 00:28:37 DTC Client (179) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:28:38 * DTC Client (179) | Initiating close of socket by core. | 2017-04-25 00:28:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:28:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:28:38 DTC Client (179) | Closed. | 2017-04-25 00:28:38 DTC - Sub Instance | Disconnected. | 2017-04-25 00:28:38 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:28:38 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:30:38 DTC Client (181) | Creating socket. | 2017-04-25 00:30:38 DTC Client (181) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:30:39 * DTC Client (181) | Initiating close of socket by core. | 2017-04-25 00:30:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:30:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:30:39 DTC Client (181) | Closed. | 2017-04-25 00:30:39 DTC - Sub Instance | Disconnected. | 2017-04-25 00:30:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:30:39 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:32:39 DTC Client (183) | Creating socket. | 2017-04-25 00:32:39 DTC Client (183) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:32:40 * DTC Client (183) | Initiating close of socket by core. | 2017-04-25 00:32:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:32:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:32:40 DTC Client (183) | Closed. | 2017-04-25 00:32:40 DTC - Sub Instance | Disconnected. | 2017-04-25 00:32:40 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:32:40 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:34:40 DTC Client (185) | Creating socket. | 2017-04-25 00:34:40 DTC Client (185) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:34:41 * DTC Client (185) | Initiating close of socket by core. | 2017-04-25 00:34:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:34:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:34:41 DTC Client (185) | Closed. | 2017-04-25 00:34:41 DTC - Sub Instance | Disconnected. | 2017-04-25 00:34:41 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:34:41 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:36:41 DTC Client (187) | Creating socket. | 2017-04-25 00:36:41 DTC Client (187) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:36:42 * DTC Client (187) | Initiating close of socket by core. | 2017-04-25 00:36:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:36:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:36:42 DTC Client (187) | Closed. | 2017-04-25 00:36:42 DTC - Sub Instance | Disconnected. | 2017-04-25 00:36:42 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:36:42 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:38:42 DTC Client (189) | Creating socket. | 2017-04-25 00:38:42 DTC Client (189) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:38:43 * DTC Client (189) | Initiating close of socket by core. | 2017-04-25 00:38:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:38:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:38:43 DTC Client (189) | Closed. | 2017-04-25 00:38:43 DTC - Sub Instance | Disconnected. | 2017-04-25 00:38:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:38:43 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:40:43 DTC Client (191) | Creating socket. | 2017-04-25 00:40:43 DTC Client (191) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:40:44 * DTC Client (191) | Initiating close of socket by core. | 2017-04-25 00:40:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:40:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:40:44 DTC Client (191) | Closed. | 2017-04-25 00:40:44 DTC - Sub Instance | Disconnected. | 2017-04-25 00:40:44 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:40:44 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:42:44 DTC Client (193) | Creating socket. | 2017-04-25 00:42:44 DTC Client (193) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:42:45 * DTC Client (193) | Initiating close of socket by core. | 2017-04-25 00:42:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:42:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:42:45 DTC Client (193) | Closed. | 2017-04-25 00:42:45 DTC - Sub Instance | Disconnected. | 2017-04-25 00:42:45 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:42:45 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:44:45 DTC Client (195) | Creating socket. | 2017-04-25 00:44:45 DTC Client (195) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:44:46 * DTC Client (195) | Initiating close of socket by core. | 2017-04-25 00:44:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:44:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:44:46 DTC Client (195) | Closed. | 2017-04-25 00:44:46 DTC - Sub Instance | Disconnected. | 2017-04-25 00:44:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:44:46 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:46:46 DTC Client (197) | Creating socket. | 2017-04-25 00:46:46 DTC Client (197) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:46:47 * DTC Client (197) | Initiating close of socket by core. | 2017-04-25 00:46:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:46:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:46:47 DTC Client (197) | Closed. | 2017-04-25 00:46:47 DTC - Sub Instance | Disconnected. | 2017-04-25 00:46:47 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:46:47 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:48:47 DTC Client (199) | Creating socket. | 2017-04-25 00:48:47 DTC Client (199) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:48:48 * DTC Client (199) | Initiating close of socket by core. | 2017-04-25 00:48:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:48:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:48:48 DTC Client (199) | Closed. | 2017-04-25 00:48:48 DTC - Sub Instance | Disconnected. | 2017-04-25 00:48:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:48:48 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:50:49 DTC Client (201) | Creating socket. | 2017-04-25 00:50:49 DTC Client (201) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:50:49 * DTC Client (201) | Initiating close of socket by core. | 2017-04-25 00:50:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:50:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:50:49 DTC Client (201) | Closed. | 2017-04-25 00:50:49 DTC - Sub Instance | Disconnected. | 2017-04-25 00:50:52 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:50:52 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:52:52 DTC Client (203) | Creating socket. | 2017-04-25 00:52:52 DTC Client (203) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:52:53 * DTC Client (203) | Initiating close of socket by core. | 2017-04-25 00:52:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:52:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:52:53 DTC Client (203) | Closed. | 2017-04-25 00:52:53 DTC - Sub Instance | Disconnected. | 2017-04-25 00:52:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:52:53 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:54:53 DTC Client (205) | Creating socket. | 2017-04-25 00:54:53 DTC Client (205) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:54:54 * DTC Client (205) | Initiating close of socket by core. | 2017-04-25 00:54:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:54:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:54:54 DTC Client (205) | Closed. | 2017-04-25 00:54:54 DTC - Sub Instance | Disconnected. | 2017-04-25 00:54:54 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:54:54 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:56:54 DTC Client (207) | Creating socket. | 2017-04-25 00:56:54 DTC Client (207) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:56:55 * DTC Client (207) | Initiating close of socket by core. | 2017-04-25 00:56:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:56:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:56:55 DTC Client (207) | Closed. | 2017-04-25 00:56:55 DTC - Sub Instance | Disconnected. | 2017-04-25 00:56:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:56:55 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 00:58:55 DTC Client (209) | Creating socket. | 2017-04-25 00:58:55 DTC Client (209) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 00:58:56 * DTC Client (209) | Initiating close of socket by core. | 2017-04-25 00:58:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 00:58:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 00:58:56 DTC Client (209) | Closed. | 2017-04-25 00:58:56 DTC - Sub Instance | Disconnected. | 2017-04-25 00:58:56 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 00:58:56 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:00:57 DTC Client (211) | Creating socket. | 2017-04-25 01:00:57 DTC Client (211) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:00:58 * DTC Client (211) | Initiating close of socket by core. | 2017-04-25 01:00:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:00:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:00:58 DTC Client (211) | Closed. | 2017-04-25 01:00:58 DTC - Sub Instance | Disconnected. | 2017-04-25 01:00:58 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:00:58 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:02:57 DTC Client (213) | Creating socket. | 2017-04-25 01:02:57 DTC Client (213) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:02:58 * DTC Client (213) | Initiating close of socket by core. | 2017-04-25 01:02:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:02:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:02:59 DTC Client (213) | Closed. | 2017-04-25 01:02:59 DTC - Sub Instance | Disconnected. | 2017-04-25 01:02:59 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:02:59 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:04:59 DTC Client (215) | Creating socket. | 2017-04-25 01:04:59 DTC Client (215) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:05:00 * DTC Client (215) | Initiating close of socket by core. | 2017-04-25 01:05:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:05:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:05:00 DTC Client (215) | Closed. | 2017-04-25 01:05:00 DTC - Sub Instance | Disconnected. | 2017-04-25 01:05:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:05:00 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:06:59 DTC Client (217) | Creating socket. | 2017-04-25 01:06:59 DTC Client (217) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:07:00 * DTC Client (217) | Initiating close of socket by core. | 2017-04-25 01:07:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:07:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:07:00 DTC Client (217) | Closed. | 2017-04-25 01:07:00 DTC - Sub Instance | Disconnected. | 2017-04-25 01:07:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:07:00 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:09:01 DTC Client (219) | Creating socket. | 2017-04-25 01:09:01 DTC Client (219) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:09:02 * DTC Client (219) | Initiating close of socket by core. | 2017-04-25 01:09:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:09:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:09:02 DTC Client (219) | Closed. | 2017-04-25 01:09:02 DTC - Sub Instance | Disconnected. | 2017-04-25 01:09:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:09:02 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:11:02 DTC Client (221) | Creating socket. | 2017-04-25 01:11:02 DTC Client (221) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:11:03 * DTC Client (221) | Initiating close of socket by core. | 2017-04-25 01:11:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:11:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:11:03 DTC Client (221) | Closed. | 2017-04-25 01:11:03 DTC - Sub Instance | Disconnected. | 2017-04-25 01:11:03 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:11:03 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:13:03 DTC Client (223) | Creating socket. | 2017-04-25 01:13:03 DTC Client (223) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:13:04 * DTC Client (223) | Initiating close of socket by core. | 2017-04-25 01:13:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:13:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:13:04 DTC Client (223) | Closed. | 2017-04-25 01:13:04 DTC - Sub Instance | Disconnected. | 2017-04-25 01:13:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:13:04 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:15:04 DTC Client (225) | Creating socket. | 2017-04-25 01:15:04 DTC Client (225) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:15:05 * DTC Client (225) | Initiating close of socket by core. | 2017-04-25 01:15:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:15:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:15:05 DTC Client (225) | Closed. | 2017-04-25 01:15:05 DTC - Sub Instance | Disconnected. | 2017-04-25 01:15:05 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:15:05 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:17:05 DTC Client (227) | Creating socket. | 2017-04-25 01:17:05 DTC Client (227) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:17:06 * DTC Client (227) | Initiating close of socket by core. | 2017-04-25 01:17:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:17:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:17:06 DTC Client (227) | Closed. | 2017-04-25 01:17:06 DTC - Sub Instance | Disconnected. | 2017-04-25 01:17:06 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:17:06 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:19:06 DTC Client (229) | Creating socket. | 2017-04-25 01:19:06 DTC Client (229) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:19:07 * DTC Client (229) | Initiating close of socket by core. | 2017-04-25 01:19:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:19:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:19:07 DTC Client (229) | Closed. | 2017-04-25 01:19:07 DTC - Sub Instance | Disconnected. | 2017-04-25 01:19:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:19:07 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:21:07 DTC Client (231) | Creating socket. | 2017-04-25 01:21:07 DTC Client (231) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:21:08 * DTC Client (231) | Initiating close of socket by core. | 2017-04-25 01:21:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:21:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:21:08 DTC Client (231) | Closed. | 2017-04-25 01:21:08 DTC - Sub Instance | Disconnected. | 2017-04-25 01:21:08 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:21:08 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:23:08 DTC Client (233) | Creating socket. | 2017-04-25 01:23:08 DTC Client (233) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:23:09 * DTC Client (233) | Initiating close of socket by core. | 2017-04-25 01:23:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:23:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:23:09 DTC Client (233) | Closed. | 2017-04-25 01:23:09 DTC - Sub Instance | Disconnected. | 2017-04-25 01:23:09 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:23:09 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:25:09 DTC Client (235) | Creating socket. | 2017-04-25 01:25:09 DTC Client (235) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:25:10 * DTC Client (235) | Initiating close of socket by core. | 2017-04-25 01:25:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:25:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:25:10 DTC Client (235) | Closed. | 2017-04-25 01:25:10 DTC - Sub Instance | Disconnected. | 2017-04-25 01:25:10 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:25:10 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:27:10 DTC Client (238) | Creating socket. | 2017-04-25 01:27:10 DTC Client (238) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:27:11 * DTC Client (238) | Initiating close of socket by core. | 2017-04-25 01:27:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:27:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:27:11 DTC Client (238) | Closed. | 2017-04-25 01:27:11 DTC - Sub Instance | Disconnected. | 2017-04-25 01:27:11 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:27:11 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:29:11 DTC Client (241) | Creating socket. | 2017-04-25 01:29:11 DTC Client (241) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:29:12 * DTC Client (241) | Initiating close of socket by core. | 2017-04-25 01:29:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:29:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:29:12 DTC Client (241) | Closed. | 2017-04-25 01:29:12 DTC - Sub Instance | Disconnected. | 2017-04-25 01:29:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:29:12 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:31:12 DTC Client (243) | Creating socket. | 2017-04-25 01:31:12 DTC Client (243) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:31:13 * DTC Client (243) | Initiating close of socket by core. | 2017-04-25 01:31:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:31:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:31:13 DTC Client (243) | Closed. | 2017-04-25 01:31:13 DTC - Sub Instance | Disconnected. | 2017-04-25 01:31:13 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:31:13 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:33:13 DTC Client (245) | Creating socket. | 2017-04-25 01:33:13 DTC Client (245) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:33:14 * DTC Client (245) | Initiating close of socket by core. | 2017-04-25 01:33:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:33:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:33:14 DTC Client (245) | Closed. | 2017-04-25 01:33:14 DTC - Sub Instance | Disconnected. | 2017-04-25 01:33:14 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:33:14 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:35:14 DTC Client (247) | Creating socket. | 2017-04-25 01:35:14 DTC Client (247) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:35:15 * DTC Client (247) | Initiating close of socket by core. | 2017-04-25 01:35:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:35:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:35:15 DTC Client (247) | Closed. | 2017-04-25 01:35:15 DTC - Sub Instance | Disconnected. | 2017-04-25 01:35:15 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:35:15 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:37:15 DTC Client (249) | Creating socket. | 2017-04-25 01:37:15 DTC Client (249) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:37:16 * DTC Client (249) | Initiating close of socket by core. | 2017-04-25 01:37:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:37:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:37:16 DTC Client (249) | Closed. | 2017-04-25 01:37:16 DTC - Sub Instance | Disconnected. | 2017-04-25 01:37:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:37:16 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:39:17 DTC Client (251) | Creating socket. | 2017-04-25 01:39:17 DTC Client (251) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:39:18 * DTC Client (251) | Initiating close of socket by core. | 2017-04-25 01:39:18 DTC Client (251) | Closed. | 2017-04-25 01:39:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:39:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:39:18 DTC - Sub Instance | Disconnected. | 2017-04-25 01:39:18 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:39:18 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:41:17 DTC Client (253) | Creating socket. | 2017-04-25 01:41:17 DTC Client (253) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:41:18 * DTC Client (253) | Initiating close of socket by core. | 2017-04-25 01:41:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:41:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:41:18 DTC Client (253) | Closed. | 2017-04-25 01:41:18 DTC - Sub Instance | Disconnected. | 2017-04-25 01:41:18 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:41:18 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:43:19 DTC Client (255) | Creating socket. | 2017-04-25 01:43:19 DTC Client (255) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:43:20 * DTC Client (255) | Initiating close of socket by core. | 2017-04-25 01:43:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:43:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:43:20 DTC Client (255) | Closed. | 2017-04-25 01:43:20 DTC - Sub Instance | Disconnected. | 2017-04-25 01:43:20 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:43:20 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:45:19 DTC Client (257) | Creating socket. | 2017-04-25 01:45:19 DTC Client (257) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:45:20 * DTC Client (257) | Initiating close of socket by core. | 2017-04-25 01:45:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:45:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:45:20 DTC Client (257) | Closed. | 2017-04-25 01:45:20 DTC - Sub Instance | Disconnected. | 2017-04-25 01:45:20 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:45:20 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:47:21 DTC Client (259) | Creating socket. | 2017-04-25 01:47:21 DTC Client (259) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:47:22 * DTC Client (259) | Initiating close of socket by core. | 2017-04-25 01:47:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:47:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:47:22 DTC Client (259) | Closed. | 2017-04-25 01:47:22 DTC - Sub Instance | Disconnected. | 2017-04-25 01:47:22 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:47:22 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:49:22 DTC Client (261) | Creating socket. | 2017-04-25 01:49:22 DTC Client (261) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:49:23 * DTC Client (261) | Initiating close of socket by core. | 2017-04-25 01:49:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:49:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:49:23 DTC Client (261) | Closed. | 2017-04-25 01:49:23 DTC - Sub Instance | Disconnected. | 2017-04-25 01:49:23 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:49:23 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:51:23 DTC Client (263) | Creating socket. | 2017-04-25 01:51:23 DTC Client (263) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:51:24 * DTC Client (263) | Initiating close of socket by core. | 2017-04-25 01:51:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:51:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:51:24 DTC Client (263) | Closed. | 2017-04-25 01:51:24 DTC - Sub Instance | Disconnected. | 2017-04-25 01:51:24 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:51:24 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:53:24 DTC Client (265) | Creating socket. | 2017-04-25 01:53:24 DTC Client (265) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:53:25 * DTC Client (265) | Initiating close of socket by core. | 2017-04-25 01:53:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:53:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:53:25 DTC Client (265) | Closed. | 2017-04-25 01:53:25 DTC - Sub Instance | Disconnected. | 2017-04-25 01:53:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:53:25 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:55:25 DTC Client (267) | Creating socket. | 2017-04-25 01:55:25 DTC Client (267) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:55:26 * DTC Client (267) | Initiating close of socket by core. | 2017-04-25 01:55:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:55:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:55:26 DTC Client (267) | Closed. | 2017-04-25 01:55:26 DTC - Sub Instance | Disconnected. | 2017-04-25 01:55:26 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:55:26 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:57:26 DTC Client (269) | Creating socket. | 2017-04-25 01:57:26 DTC Client (269) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:57:27 * DTC Client (269) | Initiating close of socket by core. | 2017-04-25 01:57:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:57:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:57:27 DTC Client (269) | Closed. | 2017-04-25 01:57:27 DTC - Sub Instance | Disconnected. | 2017-04-25 01:57:27 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:57:27 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 01:59:27 DTC Client (271) | Creating socket. | 2017-04-25 01:59:27 DTC Client (271) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 01:59:28 * DTC Client (271) | Initiating close of socket by core. | 2017-04-25 01:59:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 01:59:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 01:59:28 DTC Client (271) | Closed. | 2017-04-25 01:59:28 DTC - Sub Instance | Disconnected. | 2017-04-25 01:59:28 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 01:59:28 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:01:28 DTC Client (273) | Creating socket. | 2017-04-25 02:01:28 DTC Client (273) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:01:29 * DTC Client (273) | Initiating close of socket by core. | 2017-04-25 02:01:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:01:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:01:29 DTC Client (273) | Closed. | 2017-04-25 02:01:29 DTC - Sub Instance | Disconnected. | 2017-04-25 02:01:29 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:01:29 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:03:29 DTC Client (275) | Creating socket. | 2017-04-25 02:03:29 DTC Client (275) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:03:30 * DTC Client (275) | Initiating close of socket by core. | 2017-04-25 02:03:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:03:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:03:30 DTC Client (275) | Closed. | 2017-04-25 02:03:30 DTC - Sub Instance | Disconnected. | 2017-04-25 02:03:30 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:03:30 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:05:30 DTC Client (277) | Creating socket. | 2017-04-25 02:05:30 DTC Client (277) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:05:31 * DTC Client (277) | Initiating close of socket by core. | 2017-04-25 02:05:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:05:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:05:31 DTC Client (277) | Closed. | 2017-04-25 02:05:31 DTC - Sub Instance | Disconnected. | 2017-04-25 02:05:31 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:05:31 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:07:31 DTC Client (279) | Creating socket. | 2017-04-25 02:07:31 DTC Client (279) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:07:32 * DTC Client (279) | Initiating close of socket by core. | 2017-04-25 02:07:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:07:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:07:33 DTC Client (279) | Closed. | 2017-04-25 02:07:33 DTC - Sub Instance | Disconnected. | 2017-04-25 02:07:33 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:07:33 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:09:32 DTC Client (281) | Creating socket. | 2017-04-25 02:09:32 DTC Client (281) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:09:33 * DTC Client (281) | Initiating close of socket by core. | 2017-04-25 02:09:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:09:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:09:33 DTC Client (281) | Closed. | 2017-04-25 02:09:33 DTC - Sub Instance | Disconnected. | 2017-04-25 02:09:33 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:09:33 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:11:34 DTC Client (283) | Creating socket. | 2017-04-25 02:11:34 DTC Client (283) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:11:35 * DTC Client (283) | Initiating close of socket by core. | 2017-04-25 02:11:35 DTC Client (283) | Closed. | 2017-04-25 02:11:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:11:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:11:35 DTC - Sub Instance | Disconnected. | 2017-04-25 02:11:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:11:35 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:13:34 DTC Client (285) | Creating socket. | 2017-04-25 02:13:34 DTC Client (285) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:13:35 * DTC Client (285) | Initiating close of socket by core. | 2017-04-25 02:13:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:13:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:13:35 DTC Client (285) | Closed. | 2017-04-25 02:13:35 DTC - Sub Instance | Disconnected. | 2017-04-25 02:13:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:13:35 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:15:36 DTC Client (287) | Creating socket. | 2017-04-25 02:15:36 DTC Client (287) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:15:37 * DTC Client (287) | Initiating close of socket by core. | 2017-04-25 02:15:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:15:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:15:37 DTC Client (287) | Closed. | 2017-04-25 02:15:37 DTC - Sub Instance | Disconnected. | 2017-04-25 02:15:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:15:37 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:17:36 DTC Client (289) | Creating socket. | 2017-04-25 02:17:36 DTC Client (289) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:17:37 * DTC Client (289) | Initiating close of socket by core. | 2017-04-25 02:17:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:17:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:17:37 DTC Client (289) | Closed. | 2017-04-25 02:17:37 DTC - Sub Instance | Disconnected. | 2017-04-25 02:17:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:17:37 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:19:38 DTC Client (291) | Creating socket. | 2017-04-25 02:19:38 DTC Client (291) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:19:39 * DTC Client (291) | Initiating close of socket by core. | 2017-04-25 02:19:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:19:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:19:39 DTC Client (291) | Closed. | 2017-04-25 02:19:39 DTC - Sub Instance | Disconnected. | 2017-04-25 02:19:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:19:39 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:21:39 DTC Client (293) | Creating socket. | 2017-04-25 02:21:39 DTC Client (293) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:21:40 * DTC Client (293) | Initiating close of socket by core. | 2017-04-25 02:21:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:21:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:21:40 DTC Client (293) | Closed. | 2017-04-25 02:21:40 DTC - Sub Instance | Disconnected. | 2017-04-25 02:21:40 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:21:40 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:23:42 DTC Client (295) | Creating socket. | 2017-04-25 02:23:42 DTC Client (295) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:23:43 * DTC Client (295) | Initiating close of socket by core. | 2017-04-25 02:23:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:23:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:23:43 DTC Client (295) | Closed. | 2017-04-25 02:23:43 DTC - Sub Instance | Disconnected. | 2017-04-25 02:23:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:23:43 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:25:43 DTC Client (297) | Creating socket. | 2017-04-25 02:25:43 DTC Client (297) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:25:44 * DTC Client (297) | Initiating close of socket by core. | 2017-04-25 02:25:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:25:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:25:44 DTC Client (297) | Closed. | 2017-04-25 02:25:44 DTC - Sub Instance | Disconnected. | 2017-04-25 02:25:44 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:25:44 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:27:44 DTC Client (299) | Creating socket. | 2017-04-25 02:27:44 DTC Client (299) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:27:45 * DTC Client (299) | Initiating close of socket by core. | 2017-04-25 02:27:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:27:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:27:45 DTC Client (299) | Closed. | 2017-04-25 02:27:45 DTC - Sub Instance | Disconnected. | 2017-04-25 02:27:45 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:27:45 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:29:45 DTC Client (301) | Creating socket. | 2017-04-25 02:29:45 DTC Client (301) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:29:46 * DTC Client (301) | Initiating close of socket by core. | 2017-04-25 02:29:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:29:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:29:46 DTC Client (301) | Closed. | 2017-04-25 02:29:46 DTC - Sub Instance | Disconnected. | 2017-04-25 02:29:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:29:46 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:31:46 DTC Client (303) | Creating socket. | 2017-04-25 02:31:46 DTC Client (303) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:31:47 * DTC Client (303) | Initiating close of socket by core. | 2017-04-25 02:31:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:31:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:31:47 DTC Client (303) | Closed. | 2017-04-25 02:31:47 DTC - Sub Instance | Disconnected. | 2017-04-25 02:31:47 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:31:47 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:33:47 DTC Client (305) | Creating socket. | 2017-04-25 02:33:47 DTC Client (305) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:33:48 * DTC Client (305) | Initiating close of socket by core. | 2017-04-25 02:33:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:33:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:33:48 DTC Client (305) | Closed. | 2017-04-25 02:33:48 DTC - Sub Instance | Disconnected. | 2017-04-25 02:33:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:33:48 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:35:48 DTC Client (307) | Creating socket. | 2017-04-25 02:35:48 DTC Client (307) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:35:49 * DTC Client (307) | Initiating close of socket by core. | 2017-04-25 02:35:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:35:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:35:49 DTC Client (307) | Closed. | 2017-04-25 02:35:49 DTC - Sub Instance | Disconnected. | 2017-04-25 02:35:49 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:35:49 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:37:49 DTC Client (309) | Creating socket. | 2017-04-25 02:37:49 DTC Client (309) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:37:50 * DTC Client (309) | Initiating close of socket by core. | 2017-04-25 02:37:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:37:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:37:50 DTC Client (309) | Closed. | 2017-04-25 02:37:50 DTC - Sub Instance | Disconnected. | 2017-04-25 02:37:50 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:37:50 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:39:50 DTC Client (311) | Creating socket. | 2017-04-25 02:39:50 DTC Client (311) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:39:51 * DTC Client (311) | Initiating close of socket by core. | 2017-04-25 02:39:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:39:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:39:51 DTC Client (311) | Closed. | 2017-04-25 02:39:51 DTC - Sub Instance | Disconnected. | 2017-04-25 02:39:51 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:39:51 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:41:51 DTC Client (313) | Creating socket. | 2017-04-25 02:41:51 DTC Client (313) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:41:52 * DTC Client (313) | Initiating close of socket by core. | 2017-04-25 02:41:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:41:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:41:52 DTC Client (313) | Closed. | 2017-04-25 02:41:52 DTC - Sub Instance | Disconnected. | 2017-04-25 02:41:52 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:41:52 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:43:52 DTC Client (315) | Creating socket. | 2017-04-25 02:43:52 DTC Client (315) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:43:53 * DTC Client (315) | Initiating close of socket by core. | 2017-04-25 02:43:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:43:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:43:53 DTC Client (315) | Closed. | 2017-04-25 02:43:53 DTC - Sub Instance | Disconnected. | 2017-04-25 02:43:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:43:53 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:45:53 DTC Client (317) | Creating socket. | 2017-04-25 02:45:53 DTC Client (317) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:45:54 * DTC Client (317) | Initiating close of socket by core. | 2017-04-25 02:45:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:45:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:45:54 DTC Client (317) | Closed. | 2017-04-25 02:45:54 DTC - Sub Instance | Disconnected. | 2017-04-25 02:45:54 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:45:54 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:47:55 DTC Client (319) | Creating socket. | 2017-04-25 02:47:55 DTC Client (319) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:47:56 * DTC Client (319) | Initiating close of socket by core. | 2017-04-25 02:47:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:47:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:47:56 DTC Client (319) | Closed. | 2017-04-25 02:47:56 DTC - Sub Instance | Disconnected. | 2017-04-25 02:47:56 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:47:56 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:49:55 DTC Client (321) | Creating socket. | 2017-04-25 02:49:55 DTC Client (321) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:49:56 * DTC Client (321) | Initiating close of socket by core. | 2017-04-25 02:49:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:49:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:49:56 DTC Client (321) | Closed. | 2017-04-25 02:49:56 DTC - Sub Instance | Disconnected. | 2017-04-25 02:49:56 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:49:56 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:51:57 DTC Client (323) | Creating socket. | 2017-04-25 02:51:57 DTC Client (323) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:51:58 * DTC Client (323) | Initiating close of socket by core. | 2017-04-25 02:51:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:51:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:51:58 DTC Client (323) | Closed. | 2017-04-25 02:51:58 DTC - Sub Instance | Disconnected. | 2017-04-25 02:51:58 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:51:58 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:53:58 DTC Client (325) | Creating socket. | 2017-04-25 02:53:58 DTC Client (325) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:53:59 * DTC Client (325) | Initiating close of socket by core. | 2017-04-25 02:53:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:53:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:53:59 DTC Client (325) | Closed. | 2017-04-25 02:53:59 DTC - Sub Instance | Disconnected. | 2017-04-25 02:53:59 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:53:59 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:55:58 DTC Client (328) | Creating socket. | 2017-04-25 02:55:58 DTC Client (328) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:55:59 * DTC Client (328) | Initiating close of socket by core. | 2017-04-25 02:55:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:55:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:55:59 DTC Client (328) | Closed. | 2017-04-25 02:55:59 DTC - Sub Instance | Disconnected. | 2017-04-25 02:55:59 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:55:59 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 02:58:00 DTC Client (330) | Creating socket. | 2017-04-25 02:58:00 DTC Client (330) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 02:58:01 * DTC Client (330) | Initiating close of socket by core. | 2017-04-25 02:58:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 02:58:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 02:58:01 DTC Client (330) | Closed. | 2017-04-25 02:58:01 DTC - Sub Instance | Disconnected. | 2017-04-25 02:58:01 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 02:58:01 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:00:01 DTC Client (332) | Creating socket. | 2017-04-25 03:00:01 DTC Client (332) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:00:02 * DTC Client (332) | Initiating close of socket by core. | 2017-04-25 03:00:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:00:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:00:02 DTC Client (332) | Closed. | 2017-04-25 03:00:02 DTC - Sub Instance | Disconnected. | 2017-04-25 03:00:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:00:02 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:02:02 DTC Client (334) | Creating socket. | 2017-04-25 03:02:02 DTC Client (334) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:02:03 * DTC Client (334) | Initiating close of socket by core. | 2017-04-25 03:02:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:02:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:02:03 DTC Client (334) | Closed. | 2017-04-25 03:02:03 DTC - Sub Instance | Disconnected. | 2017-04-25 03:02:03 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:02:03 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:04:03 DTC Client (336) | Creating socket. | 2017-04-25 03:04:03 DTC Client (336) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:04:04 * DTC Client (336) | Initiating close of socket by core. | 2017-04-25 03:04:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:04:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:04:04 DTC Client (336) | Closed. | 2017-04-25 03:04:04 DTC - Sub Instance | Disconnected. | 2017-04-25 03:04:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:04:04 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:06:04 DTC Client (338) | Creating socket. | 2017-04-25 03:06:04 DTC Client (338) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:06:05 * DTC Client (338) | Initiating close of socket by core. | 2017-04-25 03:06:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:06:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:06:05 DTC Client (338) | Closed. | 2017-04-25 03:06:05 DTC - Sub Instance | Disconnected. | 2017-04-25 03:06:05 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:06:05 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:08:05 DTC Client (340) | Creating socket. | 2017-04-25 03:08:05 DTC Client (340) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:08:06 * DTC Client (340) | Initiating close of socket by core. | 2017-04-25 03:08:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:08:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:08:06 DTC Client (340) | Closed. | 2017-04-25 03:08:06 DTC - Sub Instance | Disconnected. | 2017-04-25 03:08:06 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:08:06 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:10:06 DTC Client (342) | Creating socket. | 2017-04-25 03:10:06 DTC Client (342) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:10:07 * DTC Client (342) | Initiating close of socket by core. | 2017-04-25 03:10:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:10:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:10:07 DTC Client (342) | Closed. | 2017-04-25 03:10:07 DTC - Sub Instance | Disconnected. | 2017-04-25 03:10:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:10:07 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:12:07 DTC Client (344) | Creating socket. | 2017-04-25 03:12:07 DTC Client (344) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:12:08 * DTC Client (344) | Initiating close of socket by core. | 2017-04-25 03:12:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:12:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:12:08 DTC Client (344) | Closed. | 2017-04-25 03:12:08 DTC - Sub Instance | Disconnected. | 2017-04-25 03:12:08 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:12:08 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:14:08 DTC Client (346) | Creating socket. | 2017-04-25 03:14:08 DTC Client (346) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:14:09 * DTC Client (346) | Initiating close of socket by core. | 2017-04-25 03:14:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:14:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:14:09 DTC Client (346) | Closed. | 2017-04-25 03:14:09 DTC - Sub Instance | Disconnected. | 2017-04-25 03:14:09 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:14:09 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:16:09 DTC Client (348) | Creating socket. | 2017-04-25 03:16:09 DTC Client (348) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:16:10 * DTC Client (348) | Initiating close of socket by core. | 2017-04-25 03:16:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:16:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:16:10 DTC Client (348) | Closed. | 2017-04-25 03:16:10 DTC - Sub Instance | Disconnected. | 2017-04-25 03:16:10 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:16:10 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:18:10 DTC Client (350) | Creating socket. | 2017-04-25 03:18:10 DTC Client (350) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:18:11 * DTC Client (350) | Initiating close of socket by core. | 2017-04-25 03:18:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:18:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:18:11 DTC Client (350) | Closed. | 2017-04-25 03:18:11 DTC - Sub Instance | Disconnected. | 2017-04-25 03:18:11 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:18:11 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:20:11 DTC Client (352) | Creating socket. | 2017-04-25 03:20:11 DTC Client (352) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:20:12 * DTC Client (352) | Initiating close of socket by core. | 2017-04-25 03:20:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:20:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:20:12 DTC Client (352) | Closed. | 2017-04-25 03:20:12 DTC - Sub Instance | Disconnected. | 2017-04-25 03:20:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:20:12 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:22:12 DTC Client (354) | Creating socket. | 2017-04-25 03:22:12 DTC Client (354) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:22:13 * DTC Client (354) | Initiating close of socket by core. | 2017-04-25 03:22:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:22:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:22:13 DTC Client (354) | Closed. | 2017-04-25 03:22:13 DTC - Sub Instance | Disconnected. | 2017-04-25 03:22:13 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:22:13 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:24:13 DTC Client (356) | Creating socket. | 2017-04-25 03:24:13 DTC Client (356) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:24:14 * DTC Client (356) | Initiating close of socket by core. | 2017-04-25 03:24:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:24:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:24:14 DTC Client (356) | Closed. | 2017-04-25 03:24:14 DTC - Sub Instance | Disconnected. | 2017-04-25 03:24:14 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:24:14 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:26:15 DTC Client (358) | Creating socket. | 2017-04-25 03:26:15 DTC Client (358) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:26:16 * DTC Client (358) | Initiating close of socket by core. | 2017-04-25 03:26:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:26:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:26:16 DTC Client (358) | Closed. | 2017-04-25 03:26:16 DTC - Sub Instance | Disconnected. | 2017-04-25 03:26:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:26:16 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:28:15 DTC Client (360) | Creating socket. | 2017-04-25 03:28:15 DTC Client (360) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:28:16 * DTC Client (360) | Initiating close of socket by core. | 2017-04-25 03:28:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:28:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:28:16 DTC Client (360) | Closed. | 2017-04-25 03:28:16 DTC - Sub Instance | Disconnected. | 2017-04-25 03:28:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:28:16 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:30:16 DTC Client (362) | Creating socket. | 2017-04-25 03:30:16 DTC Client (362) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:30:17 * DTC Client (362) | Initiating close of socket by core. | 2017-04-25 03:30:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:30:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:30:17 DTC Client (362) | Closed. | 2017-04-25 03:30:17 DTC - Sub Instance | Disconnected. | 2017-04-25 03:30:17 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:30:17 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:32:18 DTC Client (364) | Creating socket. | 2017-04-25 03:32:18 DTC Client (364) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:32:19 * DTC Client (364) | Initiating close of socket by core. | 2017-04-25 03:32:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:32:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:32:19 DTC Client (364) | Closed. | 2017-04-25 03:32:19 DTC - Sub Instance | Disconnected. | 2017-04-25 03:32:19 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:32:19 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:34:18 DTC Client (366) | Creating socket. | 2017-04-25 03:34:18 DTC Client (366) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:34:20 * DTC Client (366) | Initiating close of socket by core. | 2017-04-25 03:34:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:34:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:34:20 DTC Client (366) | Closed. | 2017-04-25 03:34:20 DTC - Sub Instance | Disconnected. | 2017-04-25 03:34:20 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:34:20 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:36:20 DTC Client (368) | Creating socket. | 2017-04-25 03:36:20 DTC Client (368) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:36:21 * DTC Client (368) | Initiating close of socket by core. | 2017-04-25 03:36:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:36:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:36:21 DTC Client (368) | Closed. | 2017-04-25 03:36:21 DTC - Sub Instance | Disconnected. | 2017-04-25 03:36:21 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:36:21 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:38:21 DTC Client (370) | Creating socket. | 2017-04-25 03:38:21 DTC Client (370) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:38:22 * DTC Client (370) | Initiating close of socket by core. | 2017-04-25 03:38:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:38:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:38:22 DTC Client (370) | Closed. | 2017-04-25 03:38:22 DTC - Sub Instance | Disconnected. | 2017-04-25 03:38:22 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:38:22 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:40:24 DTC Client (372) | Creating socket. | 2017-04-25 03:40:24 DTC Client (372) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:40:24 * DTC Client (372) | Initiating close of socket by core. | 2017-04-25 03:40:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:40:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:40:24 DTC Client (372) | Closed. | 2017-04-25 03:40:24 DTC - Sub Instance | Disconnected. | 2017-04-25 03:40:24 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:40:24 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:42:25 DTC Client (374) | Creating socket. | 2017-04-25 03:42:25 DTC Client (374) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:42:26 * DTC Client (374) | Initiating close of socket by core. | 2017-04-25 03:42:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:42:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:42:26 DTC Client (374) | Closed. | 2017-04-25 03:42:26 DTC - Sub Instance | Disconnected. | 2017-04-25 03:42:26 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:42:26 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:44:25 DTC Client (376) | Creating socket. | 2017-04-25 03:44:25 DTC Client (376) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:44:27 * DTC Client (376) | Initiating close of socket by core. | 2017-04-25 03:44:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:44:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:44:27 DTC Client (376) | Closed. | 2017-04-25 03:44:27 DTC - Sub Instance | Disconnected. | 2017-04-25 03:44:27 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:44:27 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:46:26 DTC Client (378) | Creating socket. | 2017-04-25 03:46:26 DTC Client (378) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:46:28 * DTC Client (378) | Initiating close of socket by core. | 2017-04-25 03:46:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:46:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:46:28 DTC Client (378) | Closed. | 2017-04-25 03:46:28 DTC - Sub Instance | Disconnected. | 2017-04-25 03:46:28 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:46:28 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:48:27 DTC Client (380) | Creating socket. | 2017-04-25 03:48:27 DTC Client (380) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:48:28 * DTC Client (380) | Initiating close of socket by core. | 2017-04-25 03:48:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:48:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:48:28 DTC Client (380) | Closed. | 2017-04-25 03:48:28 DTC - Sub Instance | Disconnected. | 2017-04-25 03:48:28 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:48:28 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:50:29 DTC Client (382) | Creating socket. | 2017-04-25 03:50:29 DTC Client (382) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:50:30 * DTC Client (382) | Initiating close of socket by core. | 2017-04-25 03:50:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:50:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:50:30 DTC Client (382) | Closed. | 2017-04-25 03:50:30 DTC - Sub Instance | Disconnected. | 2017-04-25 03:50:30 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:50:30 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:52:30 DTC Client (384) | Creating socket. | 2017-04-25 03:52:30 DTC Client (384) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:52:31 * DTC Client (384) | Initiating close of socket by core. | 2017-04-25 03:52:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:52:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:52:31 DTC Client (384) | Closed. | 2017-04-25 03:52:31 DTC - Sub Instance | Disconnected. | 2017-04-25 03:52:31 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:52:31 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:54:31 DTC Client (386) | Creating socket. | 2017-04-25 03:54:31 DTC Client (386) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:54:32 * DTC Client (386) | Initiating close of socket by core. | 2017-04-25 03:54:32 DTC Client (386) | Closed. | 2017-04-25 03:54:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:54:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:54:32 DTC - Sub Instance | Disconnected. | 2017-04-25 03:54:32 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:54:32 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:56:32 DTC Client (388) | Creating socket. | 2017-04-25 03:56:32 DTC Client (388) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:56:33 * DTC Client (388) | Initiating close of socket by core. | 2017-04-25 03:56:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:56:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:56:33 DTC Client (388) | Closed. | 2017-04-25 03:56:33 DTC - Sub Instance | Disconnected. | 2017-04-25 03:56:33 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:56:33 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 03:58:33 DTC Client (390) | Creating socket. | 2017-04-25 03:58:33 DTC Client (390) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 03:58:34 * DTC Client (390) | Initiating close of socket by core. | 2017-04-25 03:58:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 03:58:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 03:58:34 DTC Client (390) | Closed. | 2017-04-25 03:58:34 DTC - Sub Instance | Disconnected. | 2017-04-25 03:58:34 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 03:58:34 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:00:34 DTC Client (392) | Creating socket. | 2017-04-25 04:00:34 DTC Client (392) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:00:35 * DTC Client (392) | Initiating close of socket by core. | 2017-04-25 04:00:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:00:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:00:35 DTC Client (392) | Closed. | 2017-04-25 04:00:35 DTC - Sub Instance | Disconnected. | 2017-04-25 04:00:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:00:35 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:02:35 DTC Client (394) | Creating socket. | 2017-04-25 04:02:35 DTC Client (394) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:02:36 * DTC Client (394) | Initiating close of socket by core. | 2017-04-25 04:02:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:02:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:02:36 DTC Client (394) | Closed. | 2017-04-25 04:02:36 DTC - Sub Instance | Disconnected. | 2017-04-25 04:02:36 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:02:36 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:04:36 DTC Client (396) | Creating socket. | 2017-04-25 04:04:36 DTC Client (396) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:04:37 * DTC Client (396) | Initiating close of socket by core. | 2017-04-25 04:04:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:04:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:04:37 DTC Client (396) | Closed. | 2017-04-25 04:04:37 DTC - Sub Instance | Disconnected. | 2017-04-25 04:04:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:04:37 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:06:37 DTC Client (398) | Creating socket. | 2017-04-25 04:06:37 DTC Client (398) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:06:38 * DTC Client (398) | Initiating close of socket by core. | 2017-04-25 04:06:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:06:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:06:38 DTC Client (398) | Closed. | 2017-04-25 04:06:38 DTC - Sub Instance | Disconnected. | 2017-04-25 04:06:38 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:06:38 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:08:38 DTC Client (400) | Creating socket. | 2017-04-25 04:08:38 DTC Client (400) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:08:39 * DTC Client (400) | Initiating close of socket by core. | 2017-04-25 04:08:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:08:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:08:39 DTC Client (400) | Closed. | 2017-04-25 04:08:39 DTC - Sub Instance | Disconnected. | 2017-04-25 04:08:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:08:39 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:10:39 DTC Client (402) | Creating socket. | 2017-04-25 04:10:39 DTC Client (402) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:10:40 * DTC Client (402) | Initiating close of socket by core. | 2017-04-25 04:10:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:10:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:10:40 DTC Client (402) | Closed. | 2017-04-25 04:10:40 DTC - Sub Instance | Disconnected. | 2017-04-25 04:10:40 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:10:40 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:12:40 DTC Client (404) | Creating socket. | 2017-04-25 04:12:40 DTC Client (404) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:12:41 * DTC Client (404) | Initiating close of socket by core. | 2017-04-25 04:12:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:12:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:12:41 DTC Client (404) | Closed. | 2017-04-25 04:12:41 DTC - Sub Instance | Disconnected. | 2017-04-25 04:12:41 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:12:41 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:14:41 DTC Client (406) | Creating socket. | 2017-04-25 04:14:41 DTC Client (406) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:14:43 * DTC Client (406) | Initiating close of socket by core. | 2017-04-25 04:14:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:14:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:14:43 DTC Client (406) | Closed. | 2017-04-25 04:14:43 DTC - Sub Instance | Disconnected. | 2017-04-25 04:14:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:14:43 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:16:42 DTC Client (408) | Creating socket. | 2017-04-25 04:16:42 DTC Client (408) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:16:43 * DTC Client (408) | Initiating close of socket by core. | 2017-04-25 04:16:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:16:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:16:43 DTC Client (408) | Closed. | 2017-04-25 04:16:43 DTC - Sub Instance | Disconnected. | 2017-04-25 04:16:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:16:43 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:18:43 DTC Client (410) | Creating socket. | 2017-04-25 04:18:43 DTC Client (410) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:18:45 * DTC Client (410) | Initiating close of socket by core. | 2017-04-25 04:18:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:18:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:18:45 DTC Client (410) | Closed. | 2017-04-25 04:18:45 DTC - Sub Instance | Disconnected. | 2017-04-25 04:18:45 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:18:45 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:20:45 DTC Client (412) | Creating socket. | 2017-04-25 04:20:45 DTC Client (412) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:20:46 * DTC Client (412) | Initiating close of socket by core. | 2017-04-25 04:20:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:20:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:20:46 DTC Client (412) | Closed. | 2017-04-25 04:20:46 DTC - Sub Instance | Disconnected. | 2017-04-25 04:20:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:20:46 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:22:46 DTC Client (414) | Creating socket. | 2017-04-25 04:22:46 DTC Client (414) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:22:47 * DTC Client (414) | Initiating close of socket by core. | 2017-04-25 04:22:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:22:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:22:47 DTC Client (414) | Closed. | 2017-04-25 04:22:47 DTC - Sub Instance | Disconnected. | 2017-04-25 04:22:47 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:22:47 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:24:47 DTC Client (416) | Creating socket. | 2017-04-25 04:24:47 DTC Client (416) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:24:48 * DTC Client (416) | Initiating close of socket by core. | 2017-04-25 04:24:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:24:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:24:48 DTC Client (416) | Closed. | 2017-04-25 04:24:48 DTC - Sub Instance | Disconnected. | 2017-04-25 04:24:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:24:48 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:26:47 DTC Client (419) | Creating socket. | 2017-04-25 04:26:47 DTC Client (419) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:26:48 * DTC Client (419) | Initiating close of socket by core. | 2017-04-25 04:26:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:26:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:26:48 DTC Client (419) | Closed. | 2017-04-25 04:26:48 DTC - Sub Instance | Disconnected. | 2017-04-25 04:26:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:26:48 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:28:49 DTC Client (421) | Creating socket. | 2017-04-25 04:28:49 DTC Client (421) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:28:50 * DTC Client (421) | Initiating close of socket by core. | 2017-04-25 04:28:50 DTC Client (421) | Closed. | 2017-04-25 04:28:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:28:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:28:50 DTC - Sub Instance | Disconnected. | 2017-04-25 04:28:50 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:28:50 A request for the latest software update has been made. | 2017-04-25 04:29:29 * The update is being downloaded in the background. When it is complete, you will be prompted. | 2017-04-25 04:29:29 * HTTPS connection to www.sierrachart.com:443 (423) | Creating socket. Using TLS 1.2. | 2017-04-25 04:29:29 Download for software update has been redirected. Request ID: 3 -> 4 | 2017-04-25 04:29:30 HTTP connection to www.sierrachart.com:80 (424) | Creating socket. | 2017-04-25 04:29:30 HTTPS connection to www.sierrachart.com:443 (423) | Socket gracefully closed by remote side. | 2017-04-25 04:29:35 HTTPS connection to www.sierrachart.com:443 (423) | Received socket Close event | 2017-04-25 04:29:35 HTTPS connection to www.sierrachart.com:443 (423) | Initiating close of socket by core. | 2017-04-25 04:29:35 HTTPS connection to www.sierrachart.com:443 (423) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-25 04:29:35 HTTPS connection to www.sierrachart.com:443 (423) | Closed. | 2017-04-25 04:29:35 Failed to open the file: C:\SierraChart\SierraChartInstance_2\SierraChartFileDownloader.exe. Error: Windows error code 32: The process cannot access the file because it is being used by another process. | 2017-04-25 04:29:37 * HTTP connection to www.sierrachart.com:80 (424) | Socket gracefully closed by remote side. | 2017-04-25 04:29:41 HTTP connection to www.sierrachart.com:80 (424) | Received socket Close event | 2017-04-25 04:29:41 HTTP connection to www.sierrachart.com:80 (424) | Initiating close of socket by core. | 2017-04-25 04:29:41 HTTP connection to www.sierrachart.com:80 (424) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-25 04:29:41 HTTP connection to www.sierrachart.com:80 (424) | Closed. | 2017-04-25 04:29:41 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:30:50 DTC Client (425) | Creating socket. | 2017-04-25 04:30:50 DTC Client (425) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:30:51 * DTC Client (425) | Initiating close of socket by core. | 2017-04-25 04:30:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:30:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:30:51 DTC Client (425) | Closed. | 2017-04-25 04:30:51 DTC - Sub Instance | Disconnected. | 2017-04-25 04:30:51 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:30:51 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:32:52 DTC Client (427) | Creating socket. | 2017-04-25 04:32:52 DTC Client (427) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:32:53 * DTC Client (427) | Initiating close of socket by core. | 2017-04-25 04:32:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:32:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:32:53 DTC Client (427) | Closed. | 2017-04-25 04:32:53 DTC - Sub Instance | Disconnected. | 2017-04-25 04:32:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:32:53 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2017-04-25 04:34:53 DTC Client (429) | Creating socket. | 2017-04-25 04:34:53 DTC Client (429) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-04-25 04:34:54 * DTC Client (429) | Initiating close of socket by core. | 2017-04-25 04:34:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-25 04:34:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-25 04:34:54 DTC Client (429) | Closed. | 2017-04-25 04:34:54 DTC - Sub Instance | Disconnected. | 2017-04-25 04:34:54 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-25 04:34:54 d-gary |
[2017-04-25 10:02:56] |
User716402 - Posts: 28 |
I assume you got the last message log.havent I done my job yet .What is next
[2017-04-25 14:15:31] |
Kevin from trade futures for less states that rithimic's dom and data load fine and that its a problem on sierras end. I want the fastest solution and will obtain data from CQG if its not an easy fix. Please advise-Gary
[2017-04-25 16:01:01] |
You are still running the sub instance of Sierra Chart. We need to call and straighten this out for you. We are doing this now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-25 16:07:22] |
We called and left you a message. Let us know when you are available so we can call back.
[2017-04-25 17:01:17] |
A request has been initiated by trade futures for less to switch to CQG. I dont want to stop wheels already in motion. When that is done I will notify you so we can get the charts up.-Gary
[2017-04-25 17:10:44] |
OK when that is done just let us know if you need help with it. Connectivity to CQG is more simplified. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-26 20:13:42] |
charts are up -a little slower than I like- but for now OK. -Best to you
[2017-04-26 23:10:09] |
If there are any performance issues, refer to help topic 30: https://www.sierrachart.com/index.php?page=doc/helpdetails30.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-26 23:10:29
