Date/Time: Sun, 19 May 2024 07:51:06 +0000
Recorded Market Depth Data in ACSIL
View Count: 1108
[2017-04-24 18:17:10] |
User787977 - Posts: 5 |
Dear SC team, for my custom indicator I use Market Depth Data. I analyse individual DOM levels, do some calculations and then plot a graph. Only issue I have is when the chart is Reloaded/Recalculated. Everything in the indicator chart is lost. Only actual/new data are calculated. For example Market Depth Historical Graph study can be reloaded without any issue. Please see attached picture. I would like to get rid of that flat line and see actual data. Record Market Depth Data is checked for instrument used. sc.MaintainHistoricalMarketDepthData = TRUE; is set in the source code. Is there anything I can set for my custom study to use recorder market depth data when reloaded? Thank you. edit: Can "sc.SymbolData->AskDOM[x].Volume" return recorded historical market data? Date Time Of Last Edit: 2017-04-24 18:42:30
Private File |
[2017-04-25 04:44:44] |
Refer to: ACSIL Interface Members - Historical Market Depth Data (c_ACSILDepthBars) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
