Date/Time: Tue, 30 Apr 2024 21:16:16 +0000
FGBL contract problem
View Count: 1309
[2013-08-20 19:57:37] |
golan_82 - Posts: 24 |
I have a problem with the FGBL contract I'm using reversal bars in which I see in any price how many bid VS ask , and whenever there is a buy order it goes to the sell and marks it as a sell and the opposite. it only happens with this contract. so I totally get the opposite results of what really happened. it once happened with the 6E and you somehow solved the problem. what you can do about it? I talked with my broker and he told me to ask you about that.. |
[2013-08-21 01:48:09] |
This is something we do not have the ability to solve. This is completely dependent upon the data feed from the Trading service being used. If you are willing to pay for a separate EUREX data feed, we can provide you information on that. Please let us know. Keep in mind the cost for that is significant. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-21 05:46:51] |
So you say it may be because of the Eurex data feed? Is the 6E also take data from there or from somewhere else? |
