Date/Time: Sun, 19 May 2024 04:37:29 +0000
$NYMO
View Count: 1386
[2017-04-23 20:24:38] |
User713688 - Posts: 25 |
$NYMO Looking to recreate this. Anyone know how I can go about doing so? Thank you Date Time Of Last Edit: 2017-04-23 20:24:54
[2017-04-23 20:36:26] |
What specifically is the symbol for?
[2017-04-23 20:50:22] |
Developed by Sherman and Marian McClellan, the McClellan Oscillator is a breadth indicator derived from Net Advances, which is the number of advancing issues less the number of declining issues. Subtracting the 39-day exponential moving average of Net Advances from the 19-day exponential moving average of Net Advances forms the oscillator The link below goes into further detail. http://stockcharts.com/school/doku.php?st=nymo&id=chart_school:technical_indicators:mcclellan_oscillator |
[2017-04-23 21:20:20] |
Yes you can do the McClellan oscillator. Refer to: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=176#McClellan_Oscillator_-_1_Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
