Date/Time: Sun, 05 May 2024 13:19:57 +0000
Hedging and FIX compliance
View Count: 1933
[2013-08-20 18:32:21] |
Fraois - Posts: 12 |
1. Any recommended approach to host an automated system that captures two signals and may open long and short position on the same symbol without splitting the system apart and monitor it as a whole? (This automated system cannot be split cause two strategies interact with each other) 2. Wil Sierra Chart go wrong if I trade with the same account with two copies and the broker allows me to trade the same account with different sender comp ID? |
[2013-08-20 22:43:42] |
1. This is our best advice for this: One way to do this is to have your trading service set up 2 subaccounts on a trading account username that you login with. Sierra Chart can support multiple accounts. In one chart you can trade one account and in another chart for the same symbol you can trade another account. This includes automated trading as well. Trading system studies can access each others data and you can use that for some kind of synchronization. 2. The problem with this, is the position will always end up at 0 if you have a buy and sell fill of the same quantity. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-03 17:09:13] |
Hi, Sierra Chart Can you add custom connection settings for hedging and be an additional one-time charge and I can add money into my account for additional services for you to develop this? |
[2013-09-03 17:36:18] |
No. Sierra Chart does not support hedging and we have no plans for this.
