Date/Time: Wed, 08 May 2024 21:28:02 +0000
My Chart does not update
View Count: 1915
[2013-04-03 05:48:45] |
FH87 - Posts: 43 |
Some of my Chart does not update live , data connect from OEC Cry I need to refresh intraday data. How to slove this problem ? Help Date Time Of Last Edit: 2013-04-03 05:51:13
[2013-04-03 05:50:59] |
Please refer to help topic 3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-03 06:36:29] |
FH87 - Posts: 43 |
thanks for the reply Ok, I try to check the problems from the solution link |
[2013-04-13 06:13:17] |
FH87 - Posts: 43 |
I know why some charts is not updating or delay, cause OEC limit to 5 or 10 open charts
[2013-04-13 07:55:36] |
There is a limit of 5 symbols when using OEC.
