Date/Time: Wed, 15 May 2024 12:50:37 +0000
Overlay graphics studies with "Market Depth Historical Graph"
View Count: 630
[2017-04-20 16:37:33] |
gaudio fx - Posts: 1 |
Hi, I have encountered graphic problems that compromise the use of simultaneous studies The problem is that when I use the "volume by price" and "market depth historical graph" in the same chart, I can not properly view the "volume by price" because it is covered more and more by the "market depth historical graph" until it's totally uncovered below it Is it possible to have the correct display of both? I attached the screenshot thank you so much |
overlap profile from MDHG.PNG / V - Attached On 2017-04-20 16:37:25 UTC - Size: 46.95 KB - 244 views |
[2017-04-20 17:50:55] |
Refer to the Study Display Order section here about this: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#StudyDisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
