Date/Time: Mon, 29 Apr 2024 13:26:52 +0000
[Locked] - period ohlc ?
View Count: 4625
[2017-04-20 13:21:32] |
User20450 - Posts: 330 |
can you guys check this study out please , this happens to often , it works then it dosent , i have changed auto skip to yes and no with no change , main complaint is its not set to today but its plotting todays ohlc , instead of yesterdays thanks in advance |
Private File |
[2017-04-20 17:03:49] |
ElmStreetTrader - Posts: 48 |
Hi there, Which version are you referring to, the Period OHLC, Daily OHLC, or Weekly OHLC, and if you're only looking for the daily OHLC then why are you using the "Period" version? I use the Period OHLC to plot monthly levels and it does what it's supposed to do. For weekly and daily levels I use the other two. |
[2017-04-20 19:26:35] |
i have been using this for all periods i look at month , week day , as i like the way it extends out , either way somethings funky with it as u can see , shouldnt matter what i use it for , most of the time it does work fine , just for some reason it will do this few times out of the week .
[2017-05-25 15:21:29] |
any work on this , very annoying to have it change everyday
[2017-05-25 17:22:15] |
There is definitely nothing wrong. Refer to the documentation for the Forward Project OHLC Lines Input here: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=294#Period_OHLC-Variable_Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-26 19:16:17] |
well maybe you can help me figure this out cause there is something wrong , either i have it set wrong , which makes no sense cause it works sometimes and sometimes it dosent here is gold 2500 chart , im trying to plot yesterdays OHLC which its plotting , but also plotting the OHLC of today with labels , this is the problem as its cutting the OHLC at last bar for some reason my start time is 1800 to 1700 |
2017-05-26_15-04.jpg / V - Attached On 2017-05-26 19:14:25 UTC - Size: 167.38 KB - 415 views |
[2017-05-26 19:22:53] |
then here is same chart with same settings on ES and look how its plotting yesterdays OHLC perfect , so my question is whats going on that there changing or different some days and other days there fine
2017-05-26_15-21.jpg / V - Attached On 2017-05-26 19:22:06 UTC - Size: 145.56 KB - 352 views |
[2017-05-27 05:47:50] |
Explain to us in detail, what you fail to understand about the documentation we linked to in post #5 in regards to the specific Input mentioned. You should have no trouble understanding what is written for that particular Input. We have done additional updates. For your information, we cannot spend further time on this. This is marked as a user discussion. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-27 06:44:08
[2017-05-27 08:00:51] |
Hi there, The problem you are having seems to be created by the "Forward Projecting" of the OHLC lines. From what I can see, and you can verify this by watching this study in replay, is that the OHLC lines can only be a maximum length which corresponds to the length of the session. So when you forward project the lines, that "forward projection line length" is added to the length of the forming OHLC line (included as part of the session and not over and above) and once it reaches it's maximum length (session length), even though the session hasn't closed, it changes value to the next session which is today's session from yesterday's. The only way you can get round this is if you don't use forward projection or if SC includes an option for which session it is applied to. You can see what is taking place in the two attached images: |
[2017-05-27 11:54:19] |
i thought that too but when i change forward projection on the gold one nothing happens , its basicslly how u explained and platform thinks days over at that time and starts new lines where it shouldnt
[2017-05-27 11:56:55] |
my issue is somedays the charts perfect then next day its off, thete are days it does this from the open , so idk what wrong but somethings off
[2017-05-28 07:05:31] |
Try this study collection:
Date Time Of Last Edit: 2017-05-28 08:27:37
Project OHLC.StdyCollct - Attached On 2017-05-28 08:27:24 UTC - Size: 18.7 KB - 352 views Attachment Deleted. |
[2017-05-28 07:06:20] |
This is what it should look like:
Date Time Of Last Edit: 2017-05-28 08:28:49
[2017-05-28 13:16:23] |
yes daily ohlc works fine , i was pointing out issue with period ohlc as i like to use that one , but thank you
[2017-05-31 00:43:30] |
good example as period ohlc was working all month fine , now coming to the end of the month , its thinks today is last day of the month and is ploting the months close on current bar close , this is wrong
[2017-05-31 00:43:59] |
sorry forgot pic
Private File |
[2017-05-31 01:10:43] |
User695658 - Posts: 7 |
I get this same error, tends to happen near the end of the month.
[2017-05-31 01:14:57] |
We do not see a problem: http://www.sierrachart.com/image.php?Image=1496193132880.png Any analysis of specific cases are chargeable at 75 USD per hour. We are 110 percent certain there is no problem here. Refer to the documentation for the Forward Project OHLC Lines Input here: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=294#Period_OHLC-Variable_Period Also the screenshot posted in post number #16 is useless to us. There is no way from our perspective we can have any comprehension of that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-31 01:15:54
[2017-05-31 01:25:19] |
The documentation for the study makes reference to using the Line at Last Bar to Edge Draw Style but we see it is not working for the study. We will look into why and resolve that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-31 12:48:53] |
not sure whats unclear in the picture it clearly shows that last months close is on the close of the last candle , so sierra is plotting prev months close on last day of this month instead of waiting till the first , but im glad you found the issue
[2017-05-31 12:50:22] |
There is no issue. Never has been. We have not found anything. No changes have been made. The documentation for the study makes reference to using the Line at Last Bar to Edge Draw Style but we see it is not working for the study. In regards to this, you are not even using this particular Draw Style and it is unrelated.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-31 12:50:53
[2017-05-31 12:54:35] |
nothing changes if i do use that besides it bringing data all the way to end of the chart which is not where i want it , and as u can see its plotting this months OHLC , not prior months , so if im so wrong then just help me fix it
Private File |
[2017-05-31 12:59:56] |
as u can see the study stops plotting may and starts plotting junes ohlc data 2 days early , is there internal date i have to set to fix this ?
Private File |
[2017-05-31 13:28:35] |
Adam - Posts: 141 |
im experiencing this same problem.Current month is fine but previous is wrong in the last few days. Adam |
[2017-05-31 18:51:43] |
This issue is now resolved in the latest version 1564. It only happened under certain conditions.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-31 18:54:56
