Date/Time: Thu, 16 May 2024 04:17:25 +0000
Error - "Export Bar Data to Textfile"
View Count: 607
[2017-04-20 10:46:03] |
nicktrader - Posts: 665 |
I was trying to export Bar Data but I got the following message. Error starting C:\SierraChart\SierraChartTransActMA\NPP\notepad++.exe. Windows error code 267: Der Verzeichnisname ist ungültig. | 2017-04-20 12:33:47 * Error starting C:\SierraChart\SierraChartTransActMA\NPP\notepad++.exe. Windows error code 267: Der Verzeichnisname ist ungültig. | 2017-04-20 12:34:39 * Error starting C:\SierraChart\SierraChartTransActMA\NPP\notepad++.exe. Windows error code 267: Der Verzeichnisname ist ungültig. | 2017-04-20 12:35:44 * I tried it with different charts. It open my default folder "C:\SierraCharts\Data" and after "Save" I get this message. The mentioned folder in the above message is unknown. |
[2017-04-20 18:17:16] |
Refer to: http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#DailyDataEditor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
