Date/Time: Sun, 19 May 2024 10:52:04 +0000
Trade Management by Study using Attached Orders issue.
View Count: 1366
[2017-04-19 19:28:48] |
User231754 - Posts: 11 |
I am trying to Learn how to use Trade Management by Study with Attached Orders, but i am having the following issue: When Either Automated Buy/Sell Order, or Manual Order is initiated it Immediately Enters, and Exits the Trade. I can see on the Chart based on the Order Entry/Exit Arrows. I am also using the Spreadsheet System for Trading for Automated trading, but even if i Manually try to place an Order it has the same issue i have tried reading what might be wrong. |
[2017-04-20 04:08:40] |
Is it the Trade Management by Study moving one of the Attached Orders to the price level which is causing it to immediately fill? You need to look at the Trade Activity Log to determine what is happening. Refer to: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-20 13:25:06] |
I will look at the Trade Activity Log, and all other settings.
[2017-04-20 17:55:11] |
You need to look at the order prices and any order modifications.
[2017-04-24 17:10:45] |
After Examining All the Trades Using "Trade Management by Study" the Indicator i am using is causing the Immediate Fill. The Scenario occurs once a Trade is Initiated by way of another Indicator in "Spreadsheet System for Trading". In this Spreadsheet System it will Enter ,then later Reverse based on that same Indicator's Signal in the Spreadsheet. A Trailing Stop is placed with a Different Indicator in the "Trade Management by Study" this Particular Indicator Trails Upon the Original Entry until Either the Trailing Stop is Triggered, or Either the Reversal Signal is Triggered which ever Occurs First. The Issue i spoke of concerning the Immediate Exit Occurs Once a New Entry has taken place by the Spreadsheet,and then the Trailing Stop Indicator is still in the Vicinity. I will try an figure a way to keep this from happening. It seems you already knew why this was happening based on your Post #2. Thanks for your help. |
