Date/Time: Sat, 04 May 2024 09:41:40 +0000
Way to increase bar spacing
View Count: 1575
[2013-08-20 15:35:11] |
bucks - Posts: 13 |
I use multicharts and you can zoom on a tick level chart really low, they call it high definition charting. Is there a way I can emulate with sierra chart. I tried to decrease bar spacing but it stopped. Is there a way to increase. I don't care if there is a litle overlap
[2013-08-20 17:25:32] |
The documentation for this is here: https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChangingTheChartBarsPeriod Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
