Date/Time: Sat, 18 May 2024 12:27:04 +0000
volume profile webinar
View Count: 871
[2017-04-18 22:45:30] |
User333450 - Posts: 4 |
I was watching a recorded webinar by Infinity called "Step by Step Volume Profile in Sierra Charts". He said the Volume Profile chart files were already downloaded in the Chartbook file but when I go there it is completely blank. Do you know where I can find these charts? On the webinar it was listed in his Chartbook as "Volume Profile Analysis Chartbook.cht" Is this only for Infinity clients? I have my account through Stage 5 Trading, does that make a difference? Any help would be great. Thank you Guy Michaels |
[2017-04-18 23:43:45] |
Not sure where those Chartbooks are. When you get the Chartbook, you will need to change the symbols of the charts to match the symbols of the service you are using. Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#h1.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
