Date/Time: Sat, 18 May 2024 04:54:55 +0000
Control bar to new setup
View Count: 515
[2017-04-18 14:33:23] |
User84163 - Posts: 17 |
When installing from scratch on new hard drive and I want same custom control bar and also shortcuts is it (Sierra3.cfg) that I have to copy to new? I've tried but just seem to get stock setup Thanks |
[2017-04-18 14:56:14] |
Yes that is the correct file. Refer to this page: https://www.sierrachart.com/index.php?page=doc/helpdetails15.php Make sure that file is only copied to the installation folder when Sierra Chart is not running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
