Date/Time: Wed, 01 May 2024 13:04:00 +0000
How to translate sc.StudyRegionBottomCoordinate into a (price) value?
View Count: 1302
[2013-08-20 12:39:03] |
marcovth - Posts: 61 |
Hello ... How do you translate sc.StudyRegionBottomCoordinate (or any Y-offset) into a corresponding (price) value? Thanks. |
[2013-08-21 06:24:01] |
We will have to add a function for this. We will try to get this into the next release. Please check back with us in about one week.
[2013-08-21 06:25:31] |
This will be the new function: float sc.YPixelCoordinateToGraphValue(int YPixelCoordinate); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-21 06:39:52
