Date/Time: Sun, 19 May 2024 11:41:27 +0000
Date range on charts
View Count: 628
[2017-04-16 14:45:06] |
User601045 - Posts: 4 |
I can only scroll forward 5 days with my hourly chart. I want to draw geometric angles that go 5 months into the future but I cant scroll my chart forward more than 5 days. I have tried changing the date range to 5 months into the future but I still cant scroll forward more than 5 days after the last trading day. |
[2017-04-16 20:22:18] |
You need to increase the number of forward columns on the right side. Refer to: Chart Settings: Number of Forward Columns (Chart >> Chart Settings >> Display >> Chart Display Items menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-16 20:22:48
[2017-04-23 17:58:44] |
Thank you. How do I include the future dates on the axis they are missing.
[2017-04-23 18:35:23] |
This is not clear for us. You should be seeing the Dave-Times on the timescale on the right side of the chart as long as you have scrolled past the last bar. Post an image of the chart until and tell us specifically what you expect to see. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
