Date/Time: Sat, 18 May 2024 12:26:58 +0000
Custom indicator for a multi-chart/ticker indicator criteria count
View Count: 949
[2017-04-16 01:33:10] |
User170575 - Posts: 221 |
Good evening, My objective is to create an indicator that would be a count of how many tickers in a group of charts(50) have a stochastic under 20---is there an indicator that will do this or is a spreadsheet the best approach---or something else? Many many thanks, Cy |
[2017-04-17 20:02:25] |
You would have to open those 50 charts and overlay the Stochastic from all of the other charts onto one of the charts using this study: http://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php You would then have to use the Spreadsheet System/Alert study and create a formula to do what you want: http://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-17 20:03:29
