Date/Time: Sun, 05 May 2024 14:06:00 +0000
trendline spreadsheet
View Count: 1269
[2013-08-20 11:38:59] |
tubular2000 - Posts: 17 |
is there a way to draw on the chart using the standard tools(line,ellipse, text, rectangle...) from within a spreadsheet study by specifying start and end points. if so can you point me to some documentation or examples? thanks
[2013-08-20 17:32:01] |
This can only be done with ACSIL: https://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
