Date/Time: Sat, 04 May 2024 23:12:30 +0000
TT FIX multiple accounts management
View Count: 1290
[2013-08-20 09:25:34] |
Tintin - Posts: 23 |
Hello SierraChart's Team, Trying to use the TT FIX multiple accounts management. If I'm the owner of 2 accounts with TT FIX - each of them with a different Sender Comp ID and each of them with a different password and of course each of them with a different account number how can I use your new feature "support multiple trading account" ? It seems that only the multiple accounts numbers can be entered separated by a comma but what about the differents Sender Comp ID and the differents passwords ? Regards. |
[2013-08-20 09:35:45] |
In this particular case, you need to set up another copy of Sierra Chart. One for each account. If in the case where you have a single Sender Comp ID which supports multiple accounts, that is where within a single copy of Sierra Chart you can work with multiple accounts. So you could ask your broker to place both accounts under the same Sender Comp ID. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-20 09:36:31
