Date/Time: Mon, 20 May 2024 00:18:09 +0000
[Programming Help] - DRAWSTYLE_CUSTOM_VALUE_AT_Y - functionality for additional ExtraArrays
View Count: 959
[2017-04-11 05:28:41] |
User553714 - Posts: 184 |
Hi, I am using DRAWSTYLE_CUSTOM_VALUE_AT_Y to plot a value as text at a specific index but would like the ability to "stack" a number of text values at the same Bar Index; I think that drawstyle DRAWSTYLE_CUSTOM_VALUE_AT_Y works specifically with ExtraArray[0]; if it's not too much trouble in a future release could you add a few more of these drawstyles that works with several of the other ExtraArrays; DRAWSTYLE_CUSTOM_VALUE_AT_Y[0] - ExtraArray[0] DRAWSTYLE_CUSTOM_VALUE_AT_Y[1] - ExtraArray[1] DRAWSTYLE_CUSTOM_VALUE_AT_Y[2] - etc DRAWSTYLE_CUSTOM_VALUE_AT_Y[3] This would achieve the stacking of text values at a specific bar index I am after. Unless there is an easier way? Regards |
[2017-04-11 06:07:09] |
You just need to use additional study Subgraphs. There is nothing that we are able to add in this regard.
[2018-03-22 16:08:59] |
User79074 - Posts: 105 |
I believe he means if there was a vertical offset, he would be able to stack
