Date/Time: Sat, 18 May 2024 20:44:16 +0000
Mobile Device
View Count: 4447
[2017-04-10 15:40:38] |
gmorgan111 - Posts: 121 |
Can Sierra Charts be run on a mobile device such as an i pad or i phone? Thanks |
[2017-04-10 17:08:34] |
No.
[2017-04-12 20:40:58] |
User962325 - Posts: 1 |
Can Sierra Charts be run on an Android OS if a Java emulator is installed. These are the four most popular java emulators for android viz, JBED, PhoneME, Jblend and NetMite
[2017-04-12 22:16:02] |
No, this will not work. Would be best to run Sierra Chart on a Windows computer and then connect to it using a remote desktop type connection from your Android device. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
