Date/Time: Sat, 04 May 2024 21:01:27 +0000
opening range custom study
View Count: 3202
[2013-08-19 20:40:54] |
mario mario - Posts: 22 |
sobowen : I could not create DLL file, it gives the error message: -- Starting build of Custom Studies Source File: OpeningRange.cpp. -- 15:37:44 Source file "OpeningRange.cpp" is missing the SCDLLName line. Refer to ACSIL documentation. -- End of Build -- 15:37:44 please let me know if I need to change anything. thanks mario sobowen sobowen is offline User Account Join Date: Feb 2008 Posts: 15 Default Re: Opening Range Custom Study Scottorama, I have completed my opening range code. It plots the high/low for the 5, 30, and 60 minute opening ranges. A person can change the setting times for the start and/or end times for the ranges of interest. Blue annotates the highs and yellow for the lows. I am attaching the .CCP code and a chart showing the end result for your interest. This wokrs OK for me. -Steve Attached Files File Type: cpp OpeningRange.cpp (7.5 KB, 94 views) Date Time Of Last Edit: 2013-08-19 22:29:41
OpeningRange.cpp - Attached On 2013-08-19 20:36:46 UTC - Size: 7.54 KB - 528 views |
[2013-08-20 05:23:29] |
Why not instead use the built-in High/Low for Time Period study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s313 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-20 05:23:46
[2013-08-20 13:10:45] |
I am just trying to learn the program to PLOT lines & rectangles automatically for emini s&p, 3 points above and below the open. I tried to use the zigzag spreadsheet and did not understand much how exactly it works. thanks for your help |
[2013-08-21 06:42:53] |
For this you will want to use the High/Low for Time Period Study and set both the Start and End Times study inputs to the opening time. Then you will want to use 2 instances of the Study Subgraph Add study to add and subtract 3 points from the High/Low for Time Period Study Subgraph: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s272 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-22 23:05:27
[2013-08-22 13:42:45] |
I did not see study subgraph add/or menu here, is it somewhere else ?
[2013-08-22 20:10:09] |
40winks : thanks it worked, I used a horizontal line as a base instead of ohlc bar, with high/low bar period, it was calculating based on high/low of the bar irrespective of the time period. similarly, if i want the sc to draw a rectangle automatically instead of just a line, which function should I use? we have to specify the 4 corners somewhere This SC is very good, I have been using this for a long time without knowing its potential. I called TDameritrade if they support sc for stocks, they could not tell, can SC be used for stocks or just futures only? Date Time Of Last Edit: 2013-08-22 20:17:08
[2013-08-22 23:04:51] |
Sierra Chart can be used for stocks and futures. You can get stock data from TD Ameritrade but not futures data at this time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-22 23:06:27
[2013-11-04 16:20:37] |
User33681 - Posts: 37 |
You don't want tos futures data - tos sends their data in blocks and not streaming.
