Date/Time: Sat, 18 May 2024 04:38:03 +0000
Chart Trade Window Quantity Buttons
View Count: 975
[2017-04-09 09:10:06] |
ElmStreetTrader - Posts: 48 |
Hi there, Would it be possible to add in the graphics settings for the "Chart Trade Window", a field that allows you to have a different colour button for the quantity that is selected? This would help when scaling in or out of positions and order sizes are changed multiple times while one position is open and before a new position is initiated. Thanks. |
[2017-04-16 21:18:12] |
Is this possible?
[2017-04-18 17:33:06] |
Refer to: Notice: Suggestions (Currently not accepting) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
