Date/Time: Sun, 19 May 2024 06:52:28 +0000
Copy drawing from one chatbook's tab/window to a different chartbook's tab/window
View Count: 632
[2017-04-09 06:04:43] |
Dom7364 - Posts: 257 |
How do you copy drawing from one chatbook's tab/window to a different chartbook's tab/window? I am talking abot drawing that you draw yourself such with Extend rectangle tool from a chart on Workbook 1 to a chart on Workbook 2 for example.
[2017-04-10 09:54:09] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
