Date/Time: Sun, 19 May 2024 06:11:51 +0000
Help with orders
View Count: 564
[2017-04-08 17:04:38] |
fjgaspar - Posts: 62 |
Hi, I want to be able to send and order and stop. I know it is very simple thing, but I can't find how to do. I have read the order types and don't find what I need. I just need to send a order, and automatically, when filled, place a defined stop. If I send a buy order, when it is filled a defined number of tics lower a sell stop order should be submitted. If sell, the same defined number of tics in a buy stop order. How can it be performed? |
[2017-04-08 22:36:10] |
You need to use Attached Orders: Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
