Date/Time: Sun, 19 May 2024 09:22:35 +0000
Issue with Symbols List in Control Bar
View Count: 604
[2017-04-08 01:25:40] |
rc7rader - Posts: 144 |
I upgraded Sierrachart to the latest version and the behavior of the Symbols List in the Control Bar which I use in a Trade Window changed. In the previous version (below 1500), only symbols in the AWL shows up in the symbols list. Now, additional future futures contracts symbol will show up. This behavior can be annoying because so many additional symbols show up which can be confusing. I don't know the reason you did this change but I hope you can revert the symbols list behavior where it only shows the symbols that are in the AWL. See attached.
SC-problem.jpg / V - Attached On 2017-04-08 01:24:11 UTC - Size: 892.3 KB - 228 views |
[2017-04-08 09:48:18] |
We do see a problem with the watchlist symbols, and we will fix that but it is designed to show the additional contract months for the symbol of the chart.
[2017-04-08 09:58:53] |
If it is designed to show additional contract months, maybe limiting it to 3 or 4 is more than enough. After all, I don't really see any Sierra Chart futures trader trading 2 or more contract months out into the future due to liquidity of those contracts.
