Date/Time: Sun, 19 May 2024 09:47:29 +0000
Can't Connect to TransAct
View Count: 624
[2017-04-08 00:13:40] |
User488039 - Posts: 114 |
Hi, I'm not sure if this is on Sierra Charts end or TransAct, but I can't connect to TranAct? I read your latest Sticky post, and I'm not using a 3rd party firewall, and I turned off my Windows firewall for testing. I still connect to TransAct. Please let me know. Date Time Of Last Edit: 2017-04-08 01:42:42
[2017-04-08 05:40:04] |
In most cases this is going to mean that Transact server is not available at this time.
[2017-04-08 05:45:08] |
Well is there a way for you or I to check to see if it's on TransAct's end? See Attachment. Date Time Of Last Edit: 2017-04-08 06:03:54
TransAct.png / V - Attached On 2017-04-08 06:03:37 UTC - Size: 27.13 KB - 219 views |
[2017-04-08 06:06:53] |
User273702 - Posts: 2 |
At the moment I can't connect as well, they are probably doing maintenance.
[2017-04-08 06:15:19] |
Ok, well they have been down for about 7 hours.
