Date/Time: Tue, 28 May 2024 02:37:24 +0000
On Screen Trade Lots Incorrect
View Count: 533
[2017-04-07 15:42:05] |
User172040 - Posts: 70 |
When I right click in order to trade from the chart, the system wants to enter me with lots of 100 multiples. I trade 1, 2, 3 lots, not 100's. I don't know how this happened. Please see attached proof of lots when opting for lets say a buy limit. Also attached proof of lot sizes on my Trade window. Pls advise
Capture.JPG / V - Attached On 2017-04-07 15:41:53 UTC - Size: 57.43 KB - 213 views Trade Window.JPG / V - Attached On 2017-04-07 15:41:58 UTC - Size: 44.76 KB - 221 views |
[2017-04-07 17:51:46] |
It looks like you are using the wrong Trade Window. Refer to: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SettingsNotApplying Also on the Set tab of the Trade Window there is the Default Quantities button which will reset the quantities to the default. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-07 17:52:34
