Date/Time: Sat, 04 May 2024 17:33:53 +0000
indicator source code
View Count: 2411
[2013-08-19 13:42:40] |
tubular2000 - Posts: 17 |
is there a way to have the source code of the indicators included in SC to use as a starting point to built my own? it is much easier to learn from existing code than to start from scratch. i know you provide some sample in the asc_source folder, but sometimes all we need is a small modification to an existing indicator. |
[2013-08-19 17:37:36] |
/ACS_Source does not contain samples. It contains most of the actual studies in Sierra Chart. To work with that source code, refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
