Date/Time: Sun, 19 May 2024 21:02:48 +0000
Volume Graph Period Type to Fixed by Time
View Count: 556
[2017-03-31 18:33:44] |
12VMan - Posts: 44 |
I'm trying to set up Volume Profile on a DOM. There is one step in the instructions that is causing a problem. The step says to set Volume Graph Period Type to Fixed by Time. There is no option for Fixed by Time?
[2017-03-31 18:42:04] |
The documentation is old and has now been corrected. You need to set Volume Graph Period Type to From Session Start Time to End. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
