Date/Time: Tue, 28 May 2024 17:13:55 +0000
Market Depth Historical Graph
View Count: 503
[2017-03-31 11:09:07] |
User417540 - Posts: 13 |
Hi Is there a way to set the market depth historical graph to move tick by tick i.e. like a scrolling type basis at the smallest increment? tks |
[2017-03-31 17:24:58] |
The closest that you can do is to set the chart to Number of Trades Per Bar with a value of 1. Refer to: Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-31 17:25:16
