Date/Time: Tue, 28 May 2024 17:13:33 +0000
DRAWING_TEXT not refreshed
View Count: 698
[2017-03-30 16:00:33] |
User53601 - Posts: 105 |
Hello, I use the s_UseTool to draw DRAWING_TEXT on the chart. In case I do refresh of the chart, by Analysis/Studies/OK, the text drawing is not refreshed/displayed. Could you please give an advise where the issue could be? |
[2017-03-30 16:57:35] |
We need to see the code which uses sc.UseTool.
[2017-03-30 17:51:45] |
void TextDrawing (SCStudyInterfaceRef sc, float Div1, float BeginValue, int LineNumber, int Offset, int VerOffset) { // UseTool1 SCString Text01; sc.FormatString(Text01, "%.0f ", Div1 ); s_UseTool Line01; Line01.Clear(); Line01.LineNumber = LineNumber; Line01.DrawingType = DRAWING_TEXT; // Color and width if ( Div1 > 0 ) { // Line01.LineWidth = 4 ; Line01.Color = RGB(128,255,0); } else { // Line01.LineWidth = 1 ; Line01.Color = RGB(255,0,255); } Line01.Text = Text01 ; Line01.BeginDateTime = sc.BaseDateTimeIn[sc.Index-Offset]; Line01.EndDateTime = sc.BaseDateTimeIn[sc.Index-Offset]; Line01.BeginValue = BeginValue + VerOffset*sc.TickSize ; Line01.EndValue = BeginValue * VerOffset*sc.TickSize; Line01.AddMethod = UTAM_ADD_OR_ADJUST; Line01.AddAsUserDrawnDrawing = 1; sc.UseTool(Line01); }; |
[2017-03-31 01:10:11] |
We recommend looking at the /ACS_Source/studies2.cpp/ scsf_CountDownTimer study for a good example of user drawn text drawing. There is no way we can help with your own code. It is not a simple or usable example for us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
