Date/Time: Sun, 19 May 2024 18:37:27 +0000
Write bar data to file
View Count: 538
[2017-03-30 12:52:03] |
Rex1 - Posts: 14 |
is there anyway can add more option to indicator: Wirte bar data to file? 1, control which data element to be export 2, no space between date,time and price thanks Rex. |
[2017-03-30 17:50:19] |
You can modify the study. Refer to: http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
