Date/Time: Tue, 07 May 2024 16:08:40 +0000
Disconnects/ reconnects from CQG
View Count: 582
[2017-03-30 09:43:18] |
GPST10 - Posts: 139 |
Hello I need help with detecting why this is happening I got this in events viewer: Name resolution for the name fixapi.cqgtrader.com timed out after none of the configured DNS servers responded. Is this on my side or the other side? I can send log file if needed. Thanks |
[2017-03-30 09:53:52] |
This is an issue on your side with DNS. Run an Internet search for " timed out after none of the configured DNS servers responded". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
