Date/Time: Sun, 05 May 2024 22:22:32 +0000
ATR min max
View Count: 1453
[2017-03-30 07:12:02] |
AKR - Posts: 523 |
Is there a study like the ATR, but not for average but for minimum and/or maximum?
[2017-03-30 17:36:51] |
Minimum or maximum of what?
[2017-03-30 17:55:00] |
AKR - Posts: 523 |
well I use ATR on a daily chart to have the average range of a period. I would also like to have the minimum and maximum range of that same period. |
[2017-03-30 18:07:56] |
Not sure this will help, but have a look at the Study Overlay - OHLC study: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=149#Study_Overlay_-_OHLC_-_Open_High_Low_Close Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-30 18:13:04] |
AKR - Posts: 523 |
hmmmm. dont think so. but it should be pretty easy to add min and max to the ATR study, shouldnt it :-). |
[2017-04-19 20:31:16] |
User700756 - Posts: 16 |
Take a look at this site. I think this Visual ATR indicator is what you are looking for. https://sites.google.com/site/beaconcommoditytrading/home/tools-and-indicators |
[2020-11-24 01:49:46] |
whats1thingnow - Posts: 407 |
also looking for the max range for the last 10 days and vice versa min range for the last 10 days any ideas how to do this? |
