Date/Time: Fri, 03 May 2024 19:51:25 +0000
Export Bar and Study Data to Text File function
View Count: 994
[2017-03-28 18:17:35] |
Greentea - Posts: 26 |
Re: Export Bar and Study Data to Text File function Noticed it creates .txt files that read well with certain machine learning programs and even can output vwap+deviations. Just wondering if weekly and monthly pivot points can also be added to its output (only getting zeros but at least in the correct columns). |
[2017-03-29 17:40:31] |
All studies which are on the chart should be outputted to the text file. Just add the studies that you require to the chart. You may see zeros in the earlier part of the file but at some point they will become nonzero values. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
