Date/Time: Sun, 19 May 2024 11:41:36 +0000
Trade analysis
View Count: 810
[2017-03-27 10:07:39] |
nicktrader - Posts: 665 |
I trade different setups. Is there a way to analyze each different setup trade? As I know NinjaTrader support that with "Strategies" (or similiar) |
[2017-03-27 10:13:12] |
The only way is to use different Trade Accounts for the different trade setups that you use.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-27 10:13:24
[2017-03-27 10:29:57] |
For LIVE accounts not practical Many thanks |
[2017-03-27 12:11:05] |
Isn't it possible to add a field like "Setup1", "Setup2" ......
[2017-03-27 17:18:31] |
We will see about this.
[2017-04-09 11:56:31] |
Just asking if you find time to take a look on it. It would be really a big help if there is a field (or similiar)for analysing the setups. Many thanks |
[2017-04-09 19:49:20] |
This definitely is something we would not get to until next year.
