Date/Time: Tue, 07 May 2024 07:51:40 +0000
"Apply Global Symbol Settings" not working
View Count: 1522
[2013-08-17 03:38:28] |
joshtrader - Posts: 439 |
Using 1112. 1) Open a new intraday chart of AAPL, which uses 9:30 - 15:59 2) Type "QCL" to load the crude oil contract, which has 9:00 - 14:29 defined 3) Look at chart settings, and note that AAPL times still loaded. Click "Apply Global Symbol Settings." Predefined QCL times not loaded. If I open a new chart of QCL, times are correct; but I am unable to do this as described above. I do not think it should depend on the global setting for applying symbol settings, as this is used to automatically change the time when the symbol is changed. If the "Apply Global Symbol Settings" button cannot be used to manually apply a new time to a chart, and the other alternative is to automatically apply it, then what is its purpose? So, I would conclude that this is an error and not intended behavior. |
[2013-08-20 09:20:50] |
We need a little more time to look this over.
[2013-08-23 05:48:40] |
We have verified this all works as intended. This is the relevant documentation: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes This is a very deliberate design based upon a lot of experience from customer feedback. This will not change. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-23 05:49:29
