Date/Time: Tue, 14 May 2024 12:07:54 +0000
Spreadsheet disappears from chartbook
View Count: 906
[2017-03-25 18:18:49] |
GiantAvocado - Posts: 67 |
When saving a spreadsheet to .txt file, once complete the .SCSS file is gone until you reload the chartbook. I have to reload the chartbook to export any more sheets; am I doing something or is this a bug? thanks...
[2017-03-25 20:33:37] |
Do you mean the Spreadsheet window disappears? This might be an operating system problem. Not necessarily a problem within Sierra Chart. Certainly the actual spreadsheet file could not be gone. That does not make sense. We would have to get the spreadsheet file from you and test what you are doing. Attach it here following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-25 20:34:27
