Date/Time: Wed, 15 May 2024 10:12:03 +0000
SC performance
View Count: 571
[2017-03-24 16:32:43] |
User578759 - Posts: 4 |
Performance has not been an issue until I downloaded version 1527 (maybe even the version before it, I check often for new updates). Now, while in SC, their is significant lag between keystrokes and screen initiation/movement...when I'm out of SC, response time is as normal. Any known issues, cpu or otherwise, with this newer version?
[2017-03-24 17:21:46] |
Potentially there could be an issue if historical data is being downloaded. Update to the latest release. Follow these instructions: http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#FastUpdate Otherwise, there are no known issues. Therefore, refer to help topic 30: Https://www.sierrachart.com/index.php?page=doc/helpdetails30.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
